Question about HP PhotoSmart C5150 All-In-One InkJet Printer
How to fix hp. c5150 all in one printer ink failure
SOURCE: oxc18a0201 ink system failure. Apparently
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
Posted on May 28, 2009
  • 114 Answers
SOURCE: "ink system failure" message on a HP 6500 printer
Solution: HP has dropped support for the product, se\arch online forums to solve the problem.
Posted on Sep 13, 2009
MUKHTAR
  • 2022 Answers
SOURCE: HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
  • 159 Answers
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
Unable to scan photo to iPhoto
Some good news is hp has updated their software check out their hp support to see that you have the latest hp printer software.
Feb 07, 2010 | HP PhotoSmart C5150 All-In-One InkJet...
I have a HP Photosmart C5150 printer. It says it can't print, to replace the yellow ink cartridge. I have replaced the cartridge twice but I still can't get the printer to print and it is still...
Please see this link. It's a bit unorthodox as a solution, but if you've already worked through the cleaning options available at hp here, it's worth a try. Certainly cheaper than buying new cartridges that don't work.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
Error message: ink device failure oxc18a0506
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jun 18, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
Put yellow ink in and it says i need yellow ink
With a lot of ink containers they place a piece of plastic on the ink container. It must be removed befor the printer will see the new ink
Mar 06, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
Ink system failure
You can find a reset for the HP ink system failure at: http://www.inkbank.com.au/webcontent21.htm
It is for HP C7180 model, but might work with yours too...
cheers L.C.
Mar 13, 2008 | HP Photosmart 8250 InkJet Printer
HP PhotoSmart C5150 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
