Constantly stuck tape, always a mistake 03. Pull out the cassette. Another tape stuck too and error 03. This is a problem in the electronics or mechanics again? How can I fix this? Thank you.
  • kakima Dec 20, 2016
    Hi Ruslan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Ruslan
    Ruslan Dec 20, 2016
    Panasonic AG-DV2000.Jam cassette. An error has occurred on the screen F 03. He took off the lid, pulled out a cassette. I insert another cassette, the same mistake again and stuck the tape.
  • 130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
  • 64 Answers
SOURCE: Remove Cassette Error
I repair gl2s for canon and when you get a remove cassette message 9 times out of 10 it is 2 gears on the m-chassis that have failed they spit oil all over the inside and then the gear comes in contact with the m-chassis and binds up they are both white and in the middle you can see one when you open it and the other is on the inside that you cant see unless you take take the cover off and thats why you get that message but the ribbon part is something else that needs to be looked at you should send it in to a qualified canon repair facility. tell them the chassis is defective its actually code D106, E52, send those codes in with canon and make sure they see them.
Posted on Nov 16, 2007
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Posted on Jul 11, 2008
  • 4 Answers
SOURCE: the cassette door is stuck
I had a similar problem after a tape that I put in it broke while playing. With the cassette carriage in the up position (but not fully open), I did the following:
  1. Remove carriage door (two screws).
  2. Carefully pull lose (broken) tape out of the player mechanism.
  3. Remove power cord.
  4. Remove battery.
  5. Reconnect power. The cassette carriage then lowered back into the unit.
  6. Press the eject button. The cassette then rose and fully ejected.
Posted on May 10, 2010
Remove stuck cassette tape
To remove the tape you will need to pull the whole unit out of the dash and disassemble it.
Jun 11, 2017 | Kenwood Car Audio & Video
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
I have a VCR tape stuck in an old machine is there a trick to getting it out? It doesn't release it from the internal mechanisms! want the movie back!
I've had this happen to me a few times. The only way I could get the tape out was to take the VCR apart and carefully pull the tape out of the mechanism and all the tape that had pulled out of the cassette into the machine had to be carefully rewound back into the cassette. The tape itself is usually folded into many folds - so the movie needs to be copied as soon as possible onto a new cassette; as it won't play too many times with all the folds before getting stuck again into the VCR.
There is a little button near the door on the side of cassette itself that will allow you to open the door and rewind the tape easier.
Sep 21, 2009 | Televison & Video
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Cassette tape stuck
no question is silly ,it may draw juice if the power it's direct,when you turn the key on off and the cassette is still movinig or ,at the same time do this push eject & with a some thin screwdriver or pencil pull cassette out this is an old trick help me menny of times..good looking
Dec 09, 2008 | 1999 Ford Taurus
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Camera cassette errors
Often in this situation there are two issues that can casue the problem you are having. 1. The tape is casuing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. Otherwise it may need to be serviced by your local technician. Let me know how it goes.
Jun 27, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
Apr 04, 2006 | JVC HR-J461MS VHS VCR
44 people viewed this question
 Grubhead
Grubhead
