Sagemcom RT195 T2 recorder will not let me recorder programmes in the future say maximum recordings but have only used 38%.
SOURCE: Thomson TopupTV DV3 160 will not record programmes
Purchase one of the automatic searching programmable remotes. Make sure that it is a remote that can search and not one that only has a list. I found that a lot of inexpensive ones (less than £20) do get to work some basic functions - recording included. The usual way to set these up is to set the device you want to control to on and set the remote to search for the code. When the device turns off you will have found a code which you store - please note that there maybe multiple codes that work with a device and it is just a matter of trying each reactive code in turn for the closest functionality. In other words some codes might appear to change channels give menus but not work with the coloured buttons whereas another code later on the sequence might do everything. So its a long process to ensure you have the right code, but once its found - you have a remote again. It can also be setup to run multiple devices - so one control does the lot!
Posted on Jan 11, 2009
  • 1027 Answers
SOURCE: can not record dvd movie that is more than 103 minutes in length?
The solution is the quality settings on the DVD settings. On a 4.7Gb disk, 279 minutes at 24% quality, down to 70 minutes at best quality. Also, more will fit on the 8.5Gb DL disks. You can also use automatic quality, that will fit the video that you have compiled onto a disk, using the highest quality setting that will allow it to fit. An alternate method is to 'burn' to an image file on the HD, then use a program like 'DVDShrink' to fit on the disk.
Posted on Apr 13, 2009
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
  • 212 Answers
SOURCE: My thomson DTI6300 digital TV recorder shows that
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Posted on Jan 22, 2010
  • 212 Answers
SOURCE: My Thomson Top up TV box will not record. I go to
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Posted on Jan 23, 2010
I have a Philips 32PFL7562D t.v. connected via a Humax HDR-FOX T2 recorder. When I change back from a recorded programme to the T.V the screen goes blue then breaks up into 'hundreds and thousands. (s
How are you changing from recorded to TV? If you are switching the TV input, it could be because it's looking first for analogue TV stations but there are none any more, so it then reverts to the SCART and shows the Humax satellite station. If you are just pressing STOP on the Humax then you shouldn't have a problem, but if you do have the problem then the Humax must be faulty.
Sep 05, 2014 | Televison & Video
When replaying recorded programmes, it all cracks up sound and picture
sounds like maybe your computer needs more memory check on how much you have through control panel then system and that panel will show how much is installed and maximum available
i suggest you consider somewhere up to maximum on memory if you are going to do a lot with video
May 23, 2012 | Hitachi Computers & Internet
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
Sep 06, 2009 | Televison & Video
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Magnovox Dvd Recorder closing out disk
Put the disc back into the recorder.
Goto the setup menu.
Select Disc Edit. Press OK
Select Finalise. Press OK
Your DVD player is made by Funai (for future reference)
The User manual can be downloaded HERE. You need page 38.
Apr 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
