Question about Dehumidifiers
HINARI DEHUMIDIFIER DH2000, the DH2000 was making a beeping sound and the power light keeps flashing on and off, can you please tell me what is up with it. thanks
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
My dehumidifier keeps beeping??????
The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
May 05, 2011 | DeLonghi DE400 Dehumidifier
My dehumidier keeps beeping
Check the filter and make sure that the water level is correct. If all is correct then replace the water level sensor
Feb 14, 2009 | DeLonghi DE400 Dehumidifier
I HAVE A HINARI REFRESH AIR 3 IN 1 AIR CON DEHUMIDIFIER
May be a bit late for this one but if you go to www.hinari.co.uk
there is a help line with these phone numbers
CUSTOMER SERVICE: 0161 621 6900
SPARES LINE: 0161 621 6855
Anne
Dec 21, 2008 | Dehumidifiers
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
95 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
