Question about Garden
We have a John Deere Lawn Mower model number L118. It is cutting uneven on one side. One blade cuts fine but the left one scalps on one side and leaves a long rough cut on the left side. We put on new blades, but that didn't help. What else could be wrong?
  • 65 Answers
Check if blades are even ! other than that ...hummm
Posted on Jul 21, 2009
  • ralph_bruce Jul 11, 2011
    Check to see if the blades are mounted right, seems like the other blade is upside down, if blades are correct check your tire pressure, uneven tire pressure will make your cut extremely uneven..
What is the configuration of the mower deck belt on a john deere 42 inch mower deck model L118
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere L110 Lawn Tractor Service Repair Manual
Feb 25, 2017 | John Deere Garden
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Why is mower cutting one sided
Possible issues:
Mower deck not level
one of the blades are bent
the spindle isn't square to the deck or the deck itself is bent
Jul 29, 2014 | John Deere Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42" deck the dicharge side
First thing to check would be the tire pressure. I usually run 12 psi in the front and 10 psi in the rear. Next would be to check the deck bearings. If the bearings are bad in either spindle the blade will cut uneven. Easiest way to check bearings is to grab ahold of the blade and try to rock side to side. If all is ok there the deck will need to be leveled. John Deere makes a blade leveler which can be picked up at the local dealer for a few bucks. Let me know if you have any other questions or if this helps, Daniel.
Sep 05, 2011 | John Deere 22HP VTwin 48" Riding Mower
Uneven cutting, scalps
Your tires could need air, especially if it does the scalping while in a hard turn. The spindle could be cracked or the deck could be unlevel. Unless you hit something with the blades recently, I would check tire pressure first.
I hope this helps.
Jul 30, 2011 | John Deere Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Garden Logo
380 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
