Question about The Computers & Internet
The acronym BGS on the Pratley Putty packaging stands for ****** Good Stuff. True or false?
Is this true or false?
Is what true or false?
Sep 19, 2015 | Computers & Internet
Tip
How to choose your dog's bed
An average dog sleeps about 14 hours per day, more than mostof us, humans, so it is important that he has a good rest and thus acomfortable bed.There are several factors to consider when purchasing a bedfor your dog:
  • Size: of bed should match the dog . it will be inappropriate to purchase a bigdog cot for a small dog. It will look funny and it will be less comfortable forthe dog as he needs to feel cozy in his bed. It is ok, though, to get a largerbed for a puppy as it grows.
  • Long lasting: It will be wise to get a bed that is firm inits cushioning to hold for a long time.
  • Washable: Dog beds start to smell after a while so you wantto have a cushion or cover that can be rinsed or washed often. You can also tryto match the color of the cover to the color themes in your house.
  • Age factor: As they grow old, dogs will need a softercushioned bed, since they tend to have stiffer joints, like old people. You mayalso consider getting a heating device for your senior dog.
  • Allergies: Make sure that the stuffing of the bed is notsomething your dog is allergic to. If you also have a cat then make sure thatthe stuffing is not cedar as cats are allergic to that.
Have a good night sleep!
on May 16, 2012 | Dogs
Tip
Samsung Codes
If u Hav problem with installing games above 500kb on samsung Champ the use this way! my secret!! for more contact me at games.das7@gmail.com.
For Full Setting Phone reset- *2767*3855#Games memory- *#52828378#AVA TEST MENU in that go to MEMORY TEST & just changethe number 1460 to 2460 & 1700 to 2700... this makes the big games to workperfect.... 6) Then go to OTA TEST and change 500 Kb into 5 MB......... I mean500 kb to 5000 add one zero and save thats it.. 7) Then install games &enjoy...... IF, IF, IF, IF,IN UR MOBILE .YOU cannot play any game it says JAVAERROR for this problem at first restart the mobile & just follow the steps5 & 6 ok agian the games work properly 8) thats it very simple...........problem comes read this ok........................... if u do dailyu wil get practice ok then no need to read this again.
on May 01, 2012 | Samsung C3300 Champ Touch Camera Slim...
I have a leak in the pressure tank.What to do?
depending on the material solder or braise the leak, remember to drain the water and clean the area well. in south africa we have something called pratley putty which is a epoxy and hardner that works great
Apr 07, 2013 | Plumbing
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
Oct 14, 2012 | Health & Beauty
How to replace air bgs on 2002 pontiac sunfire
Driver side is easy just be sure to disconnect the battery and Red airbag wires under the dash. The Two bolts holding the driver airbag on are on the back of the steering wheel. easy stuff.
Dec 10, 2009 | 1997 Pontiac Sunfire
How to repair a chip in a fireclay farmhouse sink
Try a product called "Pratley Putty" if you can find it at your local hardware. It is a two part epoxy putty that you mix and then use as a repair agent. If you cant find it locally, e-mail me via FixYa, give me your details and I'll try source some for you or find out from the manufacturer who is local for me if thjey have an outlet in your area.
Jul 05, 2009 | Home
Bmw 318i
Hi there I had the SAME problem in my 318i. I cracked mine driving over a parking barrier in the road (long story!) Anyway. Take your car to a garage and they will drain all your oil out of the engine and sump area. They can then inject a resin into the hairline crack and once it's all set, they'll put the oil back into your car and you won't have any leak from that area again! try that first before getting a new sump. As the area needs to be bone dry from oil, they draining of oil out of your car and the waiting for the resin to set make it pretty much an all day job. Good luck with it all if you've not repaired it yet.
Jun 20, 2008 | 1999 BMW 318 ti
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
