Question about Hardware & Accessories
HOW TO SET TIMER FOR uTILITECH 154182 TO DUSK TO DAWN AND TEST
How do I program a Utilitech timer UTTNOCD2(154182)?
Lowe's has the instructions for the UTTNOCD2 (154182) on the product page: https://www.lowes.com/pd/PRIME-15-Amp-2-Outlet-Mechanical-Residential-Plug-in-Countdown-Function-Lighting-Timer/4177013 . Expand the Guides & Documents section. The direct link to the instructions is http://pdf.lowes.com/useandcareguides/054732816729_use.pdf .
After plugging in the timer, you need to rotate the black dial (clockwise or counter-clockwise) until the desired setting is lined up with arrow (at about 11 o'clock on a 12 hour analog clock). The choices are On, Off, On at dusk for the desired number of hours (even number of hours), or On at dusk and Off at dawn.
I hope this helps.
Dec 07, 2017 | Hardware & Accessories
Where can I get a dusk till dawn timer master plug did one that I wanted a TDD-MP but cannot get them anywhere so now looking for a Paget dtd timer where can k get one
  • No Paget, but lots of others
  • DUSK TILL DAWN LAMP TIMER - Nexus Industries www.nexusinds.com/masterplug/downloads/pdf/TDD.pdf · PDF file DUSK TILL DAWN LAMP TIMER SWITCHING MODES i) Timer mode ii) Random mode iii) On mode iv) Off mode v) Dusk 'Til' Dawn mode i). Timer Mode The timer will turn ...
  • Dusk to Dawn Timer ' eBay > www.ebay.com/bhp/dusk-to-dawn-timer Find great deals on eBay for Dusk to Dawn Timer in Light Timers. Shop with confidence.
  • images of dusk till dawn timer bing.com/images b3eo0&w=105&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">551o0&w=60&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">6f9o1&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">595o0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">773o0&w=107&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">fcfH0&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of dusk till dawn timer
  • Dusk to Dawn Photocell Sensor Timer Switches 10.02 www.acetek.co.uk/id66.html Acetek manufacture Dusk to till dawn photocell timer light sensitive sensor switches for energy saving lamps LED 6v 12v 24v and 240vAC
  • Dusk Till Dawn' Self-Dimming Lighting. - D-D The ... www.theaquariumsolution.com/files/Dusk Till Dawn Instructions... · PDF file 3 Step 4 - Synchronising Programme with the Plug Timer It is necessary to synchronise the Dusk till Dawn chip to the time of day during which the unit has been ...
  • Amazon.com: dusk to dawn timer www.amazon.com > Search > dusk to dawn timer Amazon.com: dusk to dawn timer. Amazon Try Prime All Go. Shop by Department. Hello. Sign in Your Account Sign in ... after 2,5 or 8 hours / Dusk to Dawn default timer
  • Items found similar to "DUSK TILL DAWN PHOTOCELL ... - eBay www.ebay.ca/sch/sis.html?_nkw=DUSK+TILL+DAWN+PHOTOCELL+SENSOR... Photocell Timer light Switch Daylight Dusk till Dawn Sensor Light switch G8. ... 5 Pcs Dusk To Dawn Photocell Light Control Auto Sensor Light socket Black.
  • Amazon.co.uk: dusk to dawn timer www.amazon.co.uk > Search > dusk to dawn timer Amazon.co.uk: dusk to dawn timer. Amazon.co.uk Try Prime All ... Battery Operated Fibre Optic Snowman, Built in dusk till dawn light sensor. Kitchen & Home: ...
  • Feb 05, 2016 | Hardware & Accessories
    Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
    Timer is probably wired incorrectly.
    Copy following links for correct wiring, and larger instructions.
    I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
    http://waterheatertimer.org/How-to-set-timers.html
    http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
    Jul 31, 2012 | Hardware & Accessories
    Utilitech #0192773 setting the timer for not working
    I do not have repair for defective timer.
    Open following link for clear large-print instructions.
    Add a comment about part of manual that does not work, for possible additional help.
    1) Timer replaces single-pole light switch only.
    2) Timer does not have a battery and must be wired correctly before programming can take place.
    3) Choose either dawn-dusk or programmable on-off:
    Timer can be set for dawn-dusk operation
    -OR-
    Timer can be set with 7-day on-off functions of your choice
    Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
    How to set utilitech wall timer for dusk/dawn settings
    The Utilitec 0192773 timer has astro dusk-to-dawn functions.
    The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
    The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
    When you are programming the timer, press TIME button and hours start flashing.
    Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
    When the sun-moon symbol shows, the display also shows AM.
    Press the +/- again and PM show.
    So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
    To continue setting astro, do not set hours, just press PROG button.
    Then repeat the steps above until: 1 OFF AM sun-moon show on display.
    Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
    I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
    Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
    Instead, go to:
    http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
    You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
    Jan 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
    How to program utilitech 2-outlet timer
    I bought a Utilitech #0192775 self-adjusting wall timer to regulate some window candles. I want to simply set it to come on from dusk to dawn, and have followed their directions the best I can. However, it does not work. Even some of the steps in the instructions are not on this model, so it is impossible to follow their directions to the "t". Do you know how to get this wall-timer to do what it says it will do? Thank you!!
    Nov 22, 2009 | Hardware & Accessories
    Hardware & Accessories Logo
    105 people viewed this question
    Top Hardware & Accessories Experts
    Gene Haynes
    Craig Butler
    Craig Butler
    Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
