My remote is broken so i want to use the buttons
SOURCE: my remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
To unlock the TV, you should have its original remote control.
http://google.com/+GopakumarGopalan
SOURCE: remote code for telefunken
2908,2900,2906. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: How do i reset a telefunken tledd-40fhd
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
