Question about HP Pavilion dv6-1030us Notebook
Hp pavillion dv6-1030us just order my new screen how do i take the front and back bezel off looking for a video link not finding all the screws on front thanks
    Novelist:
  • 154 Answers
The procedure to replace the display is outlined in the maintenance and service guide.
Refer to the Display Assembly beginning on page 81 for the "complete" disassembly instructions.
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
The maintenance guide gives you step by step procedures to remove the monitor and most importantly... how to remove the bezel "properly".
Posted on Jul 21, 2009
  • 201 Answers
There are circle stickers hiding the screws,
take out screws,bezel snaps together and snaps for removal(carefull),on each side there are small screws in the brackets.
this will free the lcd,in back of lcd is ribbon cable , must be put in straight,take note how the old one comes out
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
b>
Dec 10, 2012 | Computers & Internet
Compaq presario 1200 laptop monitor problem
This is due to a bad Backlight, or screen Inverter.
90 PERCENT OF THE TIME the fault is a bad screen Inverter,
http://www.ebay.com/itm/HP-COMPAQ-PRESARIO-1277-1275-13-1-1688-1200-1694-13-3-LCD-SCREEN-INVERTER-/330698057906?pt=LH_DefaultDomain_0&hash=item4cff23e8b2
A small primer before we continue;
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor icon.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Compaq Presario 1200 series of Notebook PC's, uses a Single CCFL.
(The exact model number is on the Bottom of the laptop. It is in a white Service Tag, and P/N = Product Number. Compaq and HP's model number)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about this thick -> O
Average length is almost as long, as the LCD screen is in height.
[ http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Look at the last 8 photos ]
A screen Inverter is used to convert the power of the laptop, for the LCD screen, and Backlight.
(LED backlighting doesn't usually use a screen Inverter.
CCFL backlighting Does)
Primer over.
The front plastic thin frame in front of the LCD screen, is the
Display Bezel.
The screen Inverter is located behind the Display bezel, and is located towards the bottom of the LCD screen.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Open the laptop to the usual 90 degree position.
AS FAR AS I CAN TELL, you do not need to remove the Display Assembly from the laptop, in order to remove the Display Bezel.
IF the Display Bezel will Not come off, with the Display Assembly attached to the laptop, I will give a link at the bottom of this section to a free Service Manual from HP Support.
There are 4 Philips head screws that go around the front, of the Display Bezel.
One at the Top Right corner, one at the Top Left corner, one at the Bottom Left corner by the left Hinge, and one at the Bottom Right corner by the right Hinge.
These are covered by Screw Covers. The screw covers can be pried off with your fingernails. If you use care you may be able to reuse them again. I stick them to the Display Bezel frame for safekeeping.
(They also like to stick to your fingers too! lol!)
If the glue is not reusable on the screw cover/s, just put a tiny little dab of Rubber Cement on them, using a toothpick.
(Try to remove any old glue first)
Use a Philips screwdriver of the right size, and remove the 4 Philips screws.
The Display Bezel is now pried off.
Use CARE as your fingernails can scratch the LCD screen.
You can lay the LCD screen back as far as it will go, then cut something to fit the LCD screen area, and be inside the inside edges of the Display Bezel.
Poster board, cardboard, cloth, etc.
Or use a pair of computer gloves.
The procedure is to lift the inside edge of the top, of the Display Bezel up a little. Then move over a few inches with your other hand, and try lifting up on another inside edge of the Display Bezel.
This will slightly flex the frame of the Display Bezel.
There are Latches on the inside of the Display Bezel, and Tabs on the Display Cover. (Cover that is the top when you close the laptop)
The Latches snap into the Tabs.
When you lift up on the inside edge of the Display Bezel, the Display Bezel will flex. Lift up, slide your fingers over under the Display Bezel, and the bezel will start popping off. Snap, snap, snap.
Keep working along, and popping those Latches loose from the Tabs.
Same principle, less screws,
http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/
Again, a different laptop than yours. Main info I want you to see is at
3:04 to 3:22,
http://www.youtube.com/watch?v=goVTe9rzAFo
The screen Inverter will be located at the bottom/middle, of the LCD Screen Frame.
Remove the screw/s that hold it on. Carefully unplug the wires to it.
Plug the wires to the new one, and remount the screen Inverter.
Snap the Display Bezel back into place, reinstall the screws, and screw covers.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=95013&
Click on -
Presario Select 1200 Series Maintenance and Service Guide
[ Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
The PDF file is downloading in the background ]
Replacing a CCFL backlight if the screen Inverter wasn't the problem;
It's TRICKY, and dangerous.
The bulb is so thin it can break in a New York minute.
It also contains MERCURY just like Fluorescent lamps used in homes, and businesses.
You may wish to seek professional help with replacing a Backlight
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 20, 2012 | Computers & Internet
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
I need to replace the LCD screen on my Toshiba Satellite P305D-S8828. Can you provide step by step guide with photos or a video?
Replacing LCD is not a big deal. Just follow these steps:-
3. Remove the screw covers. Take care not to lose any. They pop off.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out.
6. Disconnect the wires. One wire goes to the backlight, while the other goes to the video card.
7.Use exact serial no. LCD for exact replacement.
8. Connect the video wire and the backlight wireand affix it using the tape that held the original in place.
Hope they work for you. All the best
Dec 09, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
How do I take out the screen on my HP G71 -329WM laptop
I have a HP Pavilion zv6000 laptop and have replaced both the screen and the hinges, plus a few friends laptop screens all the same way. First remove the battery and unplug the laptop. To replace the screen you will need to to remove the hard drive and remove all the screws form the underside of the laptop to allow access to the underside of the keyboard as the connectors for the screen are under the bezel above the keyboard. Opening the lid all the way will make it easier to get under the keyboard t and bezel then disconnect the power, video signal, and wifi connectors. Might be 1 or 2 or 3 separate connectors. Carefully removed the rubber plugs from the front of the screen and stored them so you didn't loose them. Using a small screwdriver, remove the screws under the plugs. Using a flat screwdriver or small thin blade, carefully separate the bezel around the outside of the screen, it may be glued together so take care not to crack the plastic. At this point would can see the screen screwed in to the hinges and the back of the lid and what screws need to be removed. The wifi antenna is usually attached to both the screen and the lid via tape so take care when removing the screen. Place the new screen back and attach the hinges and connectors, making sure to place the wifi antenna back where it was located properly. At this point I plug in the laptop and verify the HP logo or POST screen appears whe I turn it on, showing that the connections are ok before unplugging and continuing to replace the remaining screws, hard drive and finally battery. Depending on how the bezel around the screen is attached, you might want to use double stick tape as the glue no longer holds the front and back together around the screen. Depending on how mechanical you are, figure between 30 and 60 minutes to replace the screen the first time.
Dec 03, 2010 | Computers & Internet
My swivel hinge on my cx2610 gateway laptop broke and I ordered a part to replace it. I am trying to find out instructions on how to remove the screen cover to replace it. Please advise
Go to your local Radio Shack and buy a fiberglass diddle stick. File down one edge so it looks like a flat blade screw driver. Now on the front side bezel there should be a couple of rubber bumpers on the front top of the screen. Remove these and you'll see a couple of screws. At the bottom front of the screen there may be a couple of plastic covers - they are colored the same as the plastic aand may be hard to see. Now to the fun part. Once all the screws are removed and the system is off and the battery removed, use the diddle stick thusly. Insert the flat blade under the front screen edge that is close to the screen viewing area. You may be able to do this with your fingers. You're trying to insert the flat blade between the plastic bezel and the METAL that surrounds the screen. Once the diddle stick is inserted between the plastic bezel and the METAL, you can slide the diddle stick along the METAL. Doing so will release the plastic catches that are inside the bezel. Once done you can lift off the bezel and see the screws securing the screen and the wires attached to the screen. For new employees in my shop, I have them use different colored markers on the screws and the connectors because it's very important that when you reassemble the unit that the proper screws go into the proper holes and the proper cables go into the proper sockets. Good Luck
Feb 25, 2010 | Gateway Computers & Internet
Children destroyed screen on new HP Pav dv6 -1245dx. How hard to re[lace screen?
They are fairly easy to replace. There should be 6 rubber screw caps/bumpers around the bezel of the lcd. Remove the covers and the phillips screws underneith. Gently remove the front bezel. Take your time doing this, because they use some adhesive strips around the sides as well as some clips. If your not careful, you will crack the bezel. Once removed there should be about 3 screws on either side of the lcd holding it to the hinges. Remove these screws. Unplug the backlight from the inverter board at the bottom of the lcd and the main flex cable from the back of the unit. Installation is the reversal of disassembly. A new LCD can be purchased on ebay for around $110-150.
Dec 12, 2009 | HP Pavilion dv6000z Notebook
Water between screens how to get out took screws around screen but it wont come off conected still looks from bottom front
Hello Remove the front Bezel and youwill find 4 more screws to remove and the screen will come off. you should have about 16 screws in total. 12 on the back and 4 from lower front. the bezel looks like a long strip in bottom of front right beneath the toshiba symbol.
Oct 22, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
HP Pavilion dv6-1030us Notebook Logo
807 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
