Question about Measuring Tools & Sensors
My model 00621 weather station display is very dim what can I do about it
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
My display is very dim on my model 00621
look on the model tag and get me a full model number, ill try and help if i can
Dec 20, 2016 | Ovens
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Have a LL where temp should be, don't know how to re-set
Is the display dim? I have seen behaviour like this when the battery is getting weak on a home weather station.
Oct 02, 2015 | Home
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
Apr 05, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
91 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
