Question about Jenn-Air JSD2789GES Side by Side Refrigerator
I installed a new module and i must rest it - Jenn-Air JSD2789GES Side by Side Refrigerator
  • alf160boss Jul 21, 2009
    thank you for suggestion, but i replaced the pc board on freezer door , that controls the funtions of crused ice , water , etc. to the freezer door.
    i replaced the control module thats on the freezer door , the board is stuck on one funtion, i was told i might need it, if so how do i reset it.
  • Jenn-Air Master
  • 8,220 Answers
Get it out and send it back. get another
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 21, 2009
  • 3,037 Answers
I believe that you replaced the water filter and need to reset the light. If so then the following should work: Press and hold the light and lock pads until the change filter light blinks ( approx 3 seconds )
Let me know how this turns out and if that's not your problem, then let me know specifically what you replaced.
Benjamin
We're is the bcm location on 98 Ford explore 4.0 v.6 sport edition
The module on this truck year is called a "GEM", BCM comes later. The GEM is located behind the radio assembly and is bolted to the IP support bracket, it has 3 large connectors. See photo below.
The following is from Alldata:
>>Prior to removal of module, it is necessary to upload module configuration information to New Generation STAR (NGS) Tester. This information needs to be downloaded into the new module once installed.
Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result<<
then after install:
>>To install, reverse the removal procedure. CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the New Generation STAR (NGS) Tester into the new module. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
Feb 22, 2016 | Ford Cars & Trucks
New broiler unit installed and not working.
Try unplugn it..alotta stuf today is about reboot...u mayhav a fuse or module at issue....checout utube
May 10, 2015 | Kitchen Ranges
2008 Malibu Body Control Module
Most of the time, the dealer has to do the programming. It requires special software to do this.
Dec 04, 2012 | 2008 Chevrolet Malibu
Where is fuel pump for 1996 mercury mystique located on the car and how do you remove it
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Multi-Port Fuel Injection (MFI) Fuel Pressure Gauge T80L-9974-B
Removal
  1. Depressurize fuel system as outlined in Service Procedures- Fuel System Pressure Relief.
  1. Remove rear seat cushion. Refer to Section 01-10.
  1. Remove plastic grommet from floor pan.
  1. Disconnect fuel pump module electrical connector.
  1. NOTE: To disconnect fuel tubes from fuel pump module, compress tabs on both sides of each nylon push connect fitting and ease fuel tube out of fuel pump module.
    Disconnect fuel and vapor return tubes from fuel pump module.
  1. Turn fuel pump locking retainer ring counterclockwise using Fuel Tank Sender Wrench D84P-9275-A or equivalent and remove fuel pump locking retainer ring.
  1. NOTE: After fuel pump module removal, immediately cover fuel pump module opening in fuel tank in order to prevent fuel system contamination.
    Remove fuel pump module and cover fuel pump module opening in fuel tank.
  1. Remove fuel pump module O-ring seal and discard.
Installation
  1. NOTE: When cleaning fuel pump module mounting surface on fuel tank, use caution to prevent any foreign material from entering fuel system.
    Clean fuel pump module mounting flange and fuel pump module mounting surface and O-ring seal groove on fuel tank.
  1. Apply a light coat of Premium Long-Life Grease XG-1-C, -K or equivalent meeting Ford specification ESA-M1C75-B on a new O-ring seal to hold it in place and install it into the O-ring seal groove on the fuel tank.
  1. Install fuel pump module carefully to ensure that filter is not damaged. Make sure that locating keys are in keyways and O-ring seal remains in place.
  1. Hold fuel pump module in place and install fuel pump locking retainer ring finger-tight. Make sure that all locking tabs are under fuel tank lock ring tabs.
  1. Secure fuel pump locking retainer ring by rotating clockwise using Fuel Tank Sender Wrench D84P-9275-A or equivalent until fuel pump locking retainer ring rests against stops.
  1. Connect fuel and vapor return tubes to fuel pump module.
  1. Connect fuel pump module electrical connector.
  1. Install plastic grommet in floor pan.
  1. Install rear seat cushion. Refer to Section 01-10.
  1. Install Multi-Port Fuel Injection (MFI) Fuel Pressure Gauge T80L-9974-B as outlined in Service Procedures-Fuel System Pressure Relief.
  1. Turn ignition switch to RUN position for three seconds repeatedly (5 to 10 times) until pressure gauge reads at least 270 kPa (30 psi). Check for leaks at fittings.
  1. Remove pressure gauge, start engine and recheck for leaks.
Hope this helps
Aug 13, 2011 | 1996 Mercury Mystique
I replaced the wiper control module and while I did that the wipers were in the up position. Now the new module is in and they are operating but come to rest in the upright position. Do I need to remove...
Perhaps, you could remove the arms and reset them, but, I am curious, did you replace the 'windshield wiper motor?' I was always taught that if the wiper arms did not come to rest in the right resting place, that the wiper motor was at fault.
Good luck on this repair.
Feb 05, 2011 | 1997 Lincoln Town Car
Locate lcm module 98 lincolin wont stay on
LCM is usually under dash above driver's feet.
They are $400. Gino on ebay fixes them a lot cheaper. Just search for lighting control module and you will find him.
SECTION 419-10: Multi-Function Electronic Control Modules 1998 Town Car Workshop Manual
REMOVAL AND INSTALLATION Module -Lighting Control (LCM) Removal
  1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of module, it is necessary to upload module configuration information to New Generation STAR (NGS) Tester. This information needs to be downloaded into the new module once installed.
    swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable.
  1. Remove the LH instrument panel lower insulator.
    1. Remove the pin-type retainers.
    1. Disconnect the courtesy lamp.
    1. Remove the LH instrument panel insulator.
  1. Position the LCM aside.
    1. Remove the screws.
    1. Release the locking tab.
  1. Remove the LCM.
    1. Disconnect the electrical connectors.
    1. Remove the LCM.
Installation
  1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the new module is installed, it is necessary to download the module configuration information from New Generation STAR (NGS) Tester into the new module.
    NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns it adaptive strategy. The vehicle may need to be drive 16 km (10 miles) or more to relearn the strategy.
Oct 30, 2010 | 1998 Lincoln Town Car
How do I install memory that's under keyboard on d830 latitude
Lift up 1 side of the keyboard cover with a small flat screwdriver.
Remove keyboard cover.
Remve three screws securing the keyboard.
Lift up the keyboard and placed it on the display panel or palm rest, so you can accss the memory slot A. The keyboard is attached to the mboard via a flat ribbon cable.
The memory slot A is located just abve the touch pad buttons.
In order to remove the existing memory module carefully spread latches on both sies of the memory slot.
The memory module will pop up at a 30 degree angle.
Pull the memory module from the slot A by the edges.
Install new ram and put everything back together.
Done!
Sep 10, 2010 | Dell Latitude D830 Laptop Computer PC...
Can't get computer to recognize memory upgrade
Hello macvalland,
Here's a 12-step memory upgrade procedure from the tigerdirect.com website:
Upgrading Your Memory to Improve Performance
Compiled By Our Editors
http://static.tigerdirect.com/html/installingmemory.html
12 Quick, Easy Steps to Installing Desktop Memory
Increasing your computer’s memory is one of the most powerful ways to improve performance.. The following 12-step guide illustrates how you can install your desktop memory upgrade in 10 minutes or less with the use of a demagnetized screwdriver. But before you begin, make sure you are working in a PC-e environment. If you handle your circuitry improperly you can inflict permanent damage. Your PC’s biggest enemy is static electricity. Static electricity can damage your module and other computer parts. You need to ground yourself to avoid "shocking" your computer. Grounding yourself removes any static electrical charge your body might be carrying. To ground yourself, you can wear antistatic wrist straps or you can do the following: With your computer turned off, touch an unpainted metal part of your computer case with your hand. Plant your feet and do not walk around (because walking can produce static electrical build-up. Now you’re ready to proceed with our 12-step program for installing memory:
1. Make sure your PC has been turned off PC! You’d be surprised how many people forget this common sense first step.
2. Remove all the power cords from your computer system.
3. Remove all the screws that secure your computer case and put them in a place where you can
easily find them..
4. Remove the computer case. Usually you can simply lift the case off once you have removed all the screws. However, if you have difficulty removing the case, consult your computer’s user manual.
5. Locate the memory slots on your motherboard. In some PCs you will find then beneath a power supply or drive. If so, you may need to remove some additional parts in order to gain access.
6. If you need the replace an existing memory module, undo the module clamps and gently lift the memory module out of the slot.
7. Take your memory module out of its anti-static bag and hold it gently by the edges. Line up the notch on the bottom of your new memory module with the empty memory slot and press the new module down with your thumbs until the pins rest snugly inside the slot. You may have to exert some pressure! When will hear a click when the memory module is installed correctly.
8. Secure the new memory module by attaching the module clamps.
9. Put the computer case back on.
10. Replace the case screws to secure the case.
11. Attach your power cord.
12. Now that your new memory has been installed, turn on your computer!
Once your memory has been physically installed, the computer must install it electronically. Once your PC is turned on, you may have to go into computer BIOS to enable your system to detect the new RAM you have just installed. Refer to your computer us
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Acer Aspire 5315 Notebook
How do I open the machine to install extra ram
Flip the laptop on its back, in the center of the bottom of the case is a large access door shaped like a free form "L". loosen the screws to this access door and pry one side open and pull the door the rest of the way. The screws maybe designed to stay on the door and only need to be loosened. Once open, you will see the RAM modules in thier sockets. Simply move the side clips away from the side of the module and it will spring up at a 45 degree angle. pull it out of the socket at that same angle, to replace, push the new socket back in at a 45 drgree angle and then push the module down untill the clips snap in place.
Jan 22, 2010 | Toshiba Satellite A105 Notebook
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
46 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
