Question about Samsung Televison & Video
UN43J5200AF is the model of my samsung tv, what are the two long slim boards located under the T-Control Board?
Marrie
  • 563 Answers
SOURCE: samsung SP43J5HF Rear Projection Tv
Hi Daml
You can find this part from Samsung UK , click HERE to check it out and also to order it. Delivery is within 7 days.
Could unfortunately not find anything for Australia.
Let me know if you need any further assistance.
Thanks for using Fixya !
Posted on Apr 30, 2008
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
Posted on Jun 18, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 1779 Answers
SOURCE: Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Posted on Aug 25, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
I have a samsung DW7933 dishwasher and was wondering where the motherboard is located ?
you are looking for the main control board on your washer it is located under the unit if you are experienced with this type of basic electronics follow the video below to locate and remove but by all means shut the circuit breaker off first before attempting any repairs.
Samsung Dishwasher Main Control Board DD8201139B
Jan 21, 2018 | Samsung Dishwashers
Where is the main control board located on a Samsung model number rf217acrs
On the back behind a protective cover or under the back bottom section enclosed inside a protective cover.
Main Control Board DA41-00695A
Appliance 911 Sea Breeze
Nov 17, 2015 | Samsung Refrigerators
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Samsung TV Model #UN55ES6500 has horizontal line across the tv. can it be timing control board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 20, 2014 | Samsung UN55ES6500 55" Class Slim LED HDTV
Why does tv not come? storm in the area last ,reset button?
Main circuit board or control board fuse inside of TV may be blown. Lightening often causes this. Not a homeowner repair.
Sep 14, 2014 | Samsung Ue46f6100 46-Inch Widescreen Full...
Samsung led tv won't power on - red power light is flashing
check the conections between psu and led bars,if the problem still,then the problem is in the led bar board.
Aug 22, 2014 | Samsung UN40D5500 40" 1080p LED TV - Ultra...
Slim Samsung HDTV will not turn on
Hello
You haven't given the exact model number to your TV here. Anyway, check its mains fuse [can be located at its power regulator board] first. If it find opened, do not replace an other; without rectifying the fulat inside the power board. If protection fuse should blow up, surely there will be some reason for that, including short circuit or failure of components.
If you replace the fuse with an other one, the fuse that you will insert will also blow up, and may cuse more faults to other components. OK.
Feb 07, 2012 | Televison & Video
Convegence board
your model has the Ics and resistors on the sub delection PCB board. You can get a new replacement board at the following link with free tech support to help you install it as it the entire large circuit board on the right side of the set. You need the board called the P54A chassis Sub deflection board under their Samsung parts category.
Heres the link.
http://servicemanuals.vstore.ca/
Aug 16, 2008 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
