Question about Ricoh Aficio 3025 All-In-One Laser Printer
We have ricoh aficio 3025 with "replace photoconductor". What are the instructions for replacing the photoconductor unit.
    New Friend:
  • 23 Answers
Https://youtu.be/ivE83hRsJuQ
Posted on Dec 25, 2016
3 Suggested Answers
SOURCE: ricoh aficio 2022 replace photoconductor unit
Photo conductor unit is the drum unit inside the copier . It contains developer and toner which are the ink as some people refer to it. It is a consumable part and needs to be replaced every 60k copies but can and dies last longer. You can ignore it and once copy quality is ok I wouldnt bother changing it but you will eventually need to replace it.
Posted on Oct 14, 2011
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
How to replace thermistor on Ricoh Aficio 3025?
Take the fuser covers off. The thermistors (I think there is 2 in this model) have red connectors. One screw for each.Check them first and see if they just have a build up of toner.
****You must have the correct ones for each Ricoh model ****
Feb 01, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
We have a Ricoh copier Aficio 1022 and the info
The Photoconductor Unit or PCU is easy to replace. The box will come with instructions but it is basically a slide in unit. They will vary in price depending on where you go. You might find one on Ebay cheaper but they generally run around $225. Keep in mind this is a drum/developer unit combination so you are replacing pretty much everything that controls copy quality.
Ricoh part number is 411018 or a type 1027 photoconductor if that helps your search.
A good source for you on parts, toner and supplies is precisionroller.com
They have everything you would need at very competetive prices with free shipping.
Not affiliated with them in any way, just use them regularly.
Good Luck
Jan 05, 2010 | Ricoh Photoconductor CLRType 145 Printer
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Erase replace photoconductor message for lanier ld015
Its cheaper to replace it. If you reset the unit in a short period of time it will lock up with used toner. Once this happens you still will have to replace the PCU plus the added cotst of the damaged gears and extra labor.
Oct 14, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Tonner and cartridge clogged wont print dark
Why do you say it's the toner? Likely the PCU (photoconductor) needs replacing, or laser optics, etc.
If it's not a 'blinking toner light' that won't go away, but rather light copies for no apparent reason, then replacing the PCU is the most likely cure.
May 15, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Need to find part #'s, parts, and service manual for drum unit,etc
I have Ricoh part numbers for the Aficio 3025, which is the EXACT same machine, using the EXACT same parts. And I assume you mean upper and lower "fuser" rollers.
Photoconductor unit P/N B205 0151
Hot Roller P/N AE01 1103
Pressure roller P/N AE02 0161
Apr 17, 2009 | Ricoh Office Equipment & Supplies
Lanier LD225 Drum Reset
There is a small "flag gear" on the back that needs to be in the "up" position to contact the button on machine and initiate it when it is installed
Feb 19, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
50 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
