Question about Blenders
I can't get the base off of the glass blending jar
4 Suggested Answers
SOURCE: Whilst blending some vegetables I accidentally
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
Posted on Jan 28, 2010
tbreeze47
  • 3083 Answers
SOURCE: Regarding the Viking Professional Blender
Here's some reviews on Amazon.com, and about halfway down the page there's a blog on stainless replacement blades. Alot of people had trouble with the plastic blades breaking, and it sounds like yours are jammed, or kind of cemented. Try soaking it in hot water (hold it upside down), to try and loosen the binding.
There's a lot of complaints about this item, and most wouldn't recommend it with the problems they've had.
Anyway, good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 04, 2010
kiira
SOURCE: the plastic threaded base for the jar on this
WARNING!!!!!
This model HB500BSS was recalled by the CPSC. blade could come off break glass and/or injure.
http://www.cpsc.gov/en/Recalls/2010/Blenders-Recalled-by-Haier-America-Due-to-Laceration-Hazard/
Posted on Nov 23, 2013
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
My blender leaks at the base of the carafe
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
Mar 07, 2014 | Oster 6700 Work Top Blender
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Replacement glass jar for 2003 Starbucks blender
Feb 02, 2013 | Braun MX2050 Blender Powermax Replacement...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Hi, Oh no!!!!!!, my blade has seized up and left little black bits of the gasket right under the blade in the jar. Can I get this gasket? We bought this absolute AWESOME Blender at the Home Show here in...
The bearing and seal are not replaceable. The bearing is sonically welded into thte base of the jar. The K-Tec is made by Blend-Tec, and any of the Blend-Tec jars will work as a direct replacement.
Sep 11, 2011 | K-Tec Champ HP3 Work Top Blender
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
My wife broke jar.I am loking for replacement
I have a replacement glass jar for you. My base broke so I am willing to sell the glass jar part. please email me at mimitascoe@gmail.com
Mar 15, 2011 | Juicelady JL600 Professional Work Top...
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
Whilst blending some vegetables I accidentally knocked the glass jar which rocked it, and the small base part that is connected to the whizzer broke. Now of course it won't work at all. Can I replace the...
Jan 27, 2010 | KitchenAid Blenders
Blenders Logo
122 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
