Question about Cameras
Set flash on iso 48 - Cameras
  • Cameras Master
  • 5,412 Answers
Which camera goes as low as ISO 48 - most only go to 100? Anyway, 48 is nearly 50, so just give an extra stop exposure.
Posted on Dec 20, 2016
Iso led keeps flashing on my eos 10s
clean the iso detect pins in the film chamber, and check to make sure they are not bent
Jan 05, 2013 | Canon EOS-10S 35mm SLR Camera
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
How do I take indoor pictures without a flash?
Best way is top set it on auto mode and keep cam steady while taking photo...
Other options are increase ISO, aperture and EV level bit increasing ISO will reduce quality of picture so try to set ISO till 400, And I will advised you to never go beyond 800...
Hope this has helped you,,, thanks...
Jul 20, 2010 | Canon PowerShot A570 IS Digital Camera
Can't take pictures w/ flash
Maybe you have the ISO set to a very high number. Set it to "auto ISO".
Sep 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Pictures are dark
The ISO (sensitivity) is set too low, like 200 ISO.
Change the ISO setting to 3200, or maximum just to see if pix become very light.
Normally, you might want to keep it around 800 ISO.
Put in new alkaline batteries to test the flash. Don't use rechargeables or "heavy duty" for this test.
Aug 30, 2009 | Cameras
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Jan 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Canon 430 EX flash problem
Were you indoors? if so, take the ISO of AUTO and out it on 400. Leave the camera set like you had it, Manual 1/60 @ 5.6. Do notuse evaluative metering. Use single spot metering or the smallest center weight setting.
Jun 28, 2008 | Cameras
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
