Need a new tube for my cookie press k4364000000
I want to know how to enable Third Party Cookies on Windows 10 please.
For enabling third party cookies follow this steps:
1. Open Internet Explorer by clicking the Start button ,
2.Click the Tools button, and then click Internet Options.
3.Click the Privacy tab, and then, under Settings,
4.Click Advanced ,Then you'll get Advanced privacy Settings window. There you can see the Third-Party cookies options.
5.For enabling Third-Party cookies, Click the Accept option. That's it.
Oct 22, 2015 | Google Chrome
What does a cookie press do?
A cookie press is basically a barrel
with a handle. You put the cookie dough in the barrel and select a cookie shape
to put at the end. By pressing down really hard on the handle, the cookie press
squeezes out a shaped cookie which you can drop straight onto a baking tray.
Feb 28, 2013 | Baking
I have a super shooter hamilton beach cookie press. the long plastic screw will not stay in place, the small plastic gear falls out.
Hi Jane,
The bolt isn't supposed to stay in one place. It's meant to turn, so the dough can be pushed to the end of the plastic tube. When you're putting the parts together, wind the bolt to one end of the long (7 inch) screw. Next, put the 1.5 inch circular disk on the same end of the column as the bolt. Then, stick the screw in the little hole; the bolt will just lay inside the hole. The screw will go almost all the way inside the handle. Then, attach the plastic tube, making sure to line up the indentations in the tube and on the circular disk. Then, add the cookie dough. When you press the handle (turning on the Super Shooter), the screw should turn, causing the round disk to move up and push the dough toward the tip/disk. I hope this helps. Happy Baking!
Dec 05, 2010 | Hamilton Beach Microwave Ovens
The problem is I don't have any instructions. This pastrty press is way old.
maybe this will help :)
cookie presses come in a wide variety of choices; some are even electric, but there is nothing like a good old-fashioned cookie press for the sheer fun of use and the quality of the end product. The Mirro Cookie Press contains a central cylinder with a screw-on end that holds the cookie extrusion plates and tips for shaping cookies and pastries. On the other end of the cylinder is a cap with a large screw running through the center. On the outside of the cap is a handle for turning the press inside the cylinder. The screw is attached to a plate, which pushes the dough through the cookie press shaping plate or tip onto the cookie sheet, and it's ready to bake. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Difficulty: Moderately Easy Instructions Things You'll Need:
  • Recipe and ingredients for cookie dough
  • Soft dishcloth
  • Mirro Cookie press with at least one plate
  • Non-stick cookie sheet
  • Spatula
  • Cooling rack
  1. Step 1 Wash the cookie press and the plates in hot soapy water. Handle the press carefully to avoid damaging the threaded ends of the cylinder or the screw-on caps. Dry all parts thoroughly with a soft dishcloth.
  2. Step 2 Screw the pressure plate all the way inside the top cap and screw it onto the cylinder.
  3. Step 3 Prepare the cookie dough. See links below for recipes or look for any recipe labeled "pressed cookies" (sometimes called "spritz" cookies.) Follow the recipe directions exactly as the right consistency is extremely important when making pressed cookies. The dough should be soft but not crumbly.
  4. Step 4 Fill the cylinder with the dough. At this point, if you realize the dough is too stiff, you might try adding an egg yolk. If the dough is too moist, add more flour a tablespoon at a time.
  5. Step 5 Place the extrusion plate or pastry tip inside the bottom lid and screw it onto the cylinder. Turn the handle until the dough is ready to come out of the extrusion plate or pastry tip.
  6. Step 6 Place the bottom of the cookie press on the baking sheet and turn the handle until enough dough has come out to see the shape of the cookie. Carefully lift the cookie press straight up so as not to smear the dough.
  7. Step 7 Bake according to the instructions for the recipe. Let cookies set on cookie sheet for 3 to 5 minutes before removing with a spatula. Place the cookies on a cooling rack.
Mar 27, 2010 | Kitchen Appliances - Others
How reset cookies token
i cant config reset token
Jul 30, 2009 | Yahoo Messenger
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Wont let me on you tube
you have to clear your browser cookies!
To delete cookies in Internet Explorer 7.0
• Select "Tools"
• Select "Internet Options".
• Open the "General" tab.
• In "Browsing history" area click the "Delete" button.
• In "Delete browsing history" window click "Delete cookies" button and then click "Yes".
• Click Close and then click OK.
To delete cookies in Internet Explorer 6.x
• Select "Tools"
• Click the "Delete cookies" button.
• Click OK.
To delete cookies Firefox 2.0
1. Select "Tools"
2. Select "Options".
3. Select "Privacy".
4. In Private area click "Clear Now".
5. In "Clear Private Data" window put the check mark for "Cookies" and click "Clear Private Data Now".
6. Click OK.
fire fox 3.7
ctrl + shft + del (press this keys @ the same time)
Apr 13, 2009 | YouTube Videos
Cannot access u tube says port 80 problem exceeds server?have a mac
Go to Tools. Hit Options. Hit the Privacy button. Press "Show Cookies" in the middle of the page. Go all the way down to and double click on it. Click on the first one. It will tell you something in the space called "Content".in the description. On the server problem on You Tube, look at what is says. It will say stuff like :
(First part)I_D pageKittyKat (Second part)133bd4455.
you look at each cookie description content and find the 2 that match the first and second part of the error.
Delete those cookies. Refresh the page. IT will work find, AND WILL LET YOU LOG IN.
The reason behind the error:
This is something that happens when a user signs in and out of their youtube account constantly or sees many people's channels nonstop.
Feb 20, 2009 | YouTube Videos
Youtube problems
i cant go on youtube
Jan 13, 2009 | YouTube Videos
No youtube
     Clear the Cache and Delete the Cookies from site(s) that cause problems: Tools > Options > Advanced > Network > Offline Storage (Cache): "Clear Now"
Tools > Options > Privacy > Cookies: "Show Cookies"
     If that didn't help then try to delete cookies.sqlite and cookies.txt that's if it existed in the Profile Folder in case there is a problem with the file.
Dec 23, 2008 | YouTube Videos
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
