I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Original remote took 2 AAA batteries and the replacement takes 2 AA batteries other than that they look identical
  • 5 Answers
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Posted on Dec 24, 2016
My TV show Retail lock and when I click on any button it still say samething plz help me to unlock it
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Jun 07, 2015 | Toshiba Original CT-90325 TV Remote...
HOW TO CHANGE INPUT ON TV
Go to menu and set up section, should give choice of inputs.
Feb 16, 2015 | Toshiba Original CT-90325 TV Remote...
Our Toshiba CT-90325 keeps turning off by itself after 10 minutes. Can I fix this?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 12, 2015 | Toshiba Original CT-90325 TV Remote...
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
How do i enter codes on a toshiba ct-90325
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 22, 2014 | Toshiba Original CT-90325 TV Remote...
I need the codes for a toshiba tv model 26av600a
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805204&rpn=undefined&modelFilter=40E200U1&selCategory=2797337&selFamily=2838040#
Page 49
The CT-90325 remote is not actually a universal. It's made to control certain DVD players through the HDMI port with something called REGZA-LINK. If you have said DVD player the link provided above and corresponding page number should be the answer you are hoping to get.
Dec 03, 2012 | Televison & Video
My remote Ct-90325 for a toshiba tv keeps saying not available when I press any button
My only suggestion is to read the owner manual to see if the set has a lock out feature that stops the remote from doing any functions.
Jun 13, 2012 | Toshiba Ct-90302 Remote Control
Manual for toshiba ct-90325 remote tv
Can't find a manual for this remote. However, try this link for a way to get it to operate:
How to Find Codes for Toshiba Remote Control Techwalla com
May 11, 2012 | Toshiba Ct90325 Remote Control
Toshiba ct-90325 remote will not work
I seemingly had the same problem, it just wouldn't turn on the tv or do anything for that matter so I popped the controller open to have a look and noticed that there was a small square box capacitor where the "cheap" metal that was making contacts with the circuit board had broken so I re-soldered the broken pieces and voila it worked. Cheers I hoped this helps some of you that have this same problem.
Jan 16, 2012 | Toshiba 32A41 32" TV
How do i Program the toshiba ct-90325 remote control to my toshiba dvd player .
Page 49
Feb 17, 2011 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
