Question about Kitchen Appliances - Others
Need a new dough tube - Kitchen Appliances - Others
When mixing cookie dough my kitchenaid mixer bogs down when the dough gets thicker .. replaced the brushes already and runs better but still bogs down .. does it need a new motor?
When using the dough hook the speed should be no higher than 2. That said, there is a limit as to how thick a dough the Artisan mixer can handle and you may well have reached that. Under these circumstances it is normal for the motor to slow down.
If the stress becomes too great, the worm (follower) gear will fail protecting the motor from burning out.
The Service Manual covering your model can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 05, 2017 | KitchenAid Food Mixers
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
I have a super shooter hamilton beach cookie press. the long plastic screw will not stay in place, the small plastic gear falls out.
Hi Jane,
The bolt isn't supposed to stay in one place. It's meant to turn, so the dough can be pushed to the end of the plastic tube. When you're putting the parts together, wind the bolt to one end of the long (7 inch) screw. Next, put the 1.5 inch circular disk on the same end of the column as the bolt. Then, stick the screw in the little hole; the bolt will just lay inside the hole. The screw will go almost all the way inside the handle. Then, attach the plastic tube, making sure to line up the indentations in the tube and on the circular disk. Then, add the cookie dough. When you press the handle (turning on the Super Shooter), the screw should turn, causing the round disk to move up and push the dough toward the tip/disk. I hope this helps. Happy Baking!
Chris
Dec 05, 2010 | Hamilton Beach Microwave Ovens
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
I have model # ABM600-1 and i need a new Dough
Put this item number (310187306559) into an ebay search and it will pull it up.
Nov 17, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Black goo type liquid oozing from under dough hook when done.
Sounds to me like your seal is bad and you need a new bread pan, which includes the seal. Call phone no. in your manual to get the part you need.
Dec 06, 2008 | Sunbeam 5891 Bread Maker
Kitchen Appliances - Others Logo
47 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
