Question about Kitchen Ranges
Is all 3 burners supposed to burn even on low ? And does the heat cut on and off ?
    Top Expert:
  • Kitchen Ranges Master
  • 52,175 Answers
Doubt they all burn except on high low will be 1 med will be 2 and HI all 3 . unless it is controlled by a thermostat the flames do not adjust automatically .
Posted on Dec 20, 2016
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
I have pyromaster gas logs that has low gas flow
Sounds like a ventilation problem... they're not getting enough air. That's a real safety problem. Make sure they have enough fresh air, and that the room itself does also. This issue is a major safety problem, and if more ventilation does not fix the issue, stop using it! Gas burners are not supposed to stay on without a flame present!
Apr 12, 2017 | Heating & Cooling
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
One burner will not burn unless you hold in the control knob as though it is being ignited and also has lot temp. when cooking even on high heat setting....thanks
If this is an LP grill and the flames are very low when all the burners are on, then try replacing the regulator and hose.
Jun 25, 2011 | Jenn-Air Grilling
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a GE (Rheem) SmartWater SmartShield Sensor gas cut off
The click you hear is the gas valve shutting off flow. It does that because the thermocouple (a rod sticking into the flame of the pilot) voltage drops, usually below 13 millivolts or so. Might be a loose connection from thermo to valve body (should be finger tight plus 1/4 turn) or a bad thermo ($13 at Lowe's). Good Luck.
Sep 28, 2009 | Heating & Cooling
Low burn speed
I had the same problem before upgrading my RAM. Seems video burning software like nero are RAM hogs; if you do not have a large amount of RAM then it slowers the burning speed down to a crawl.[ BTW I didn't get maximum burning speeds using nero on a Windows Vista computer until I upgraded to 2 GB RAM] Hope this helps & please remember to rate my answer.
Dec 31, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
