Question about JVC Televison & Video
I need to connect a jvc sppwc30 to a television s
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
Jvc customer service
can i take the channel locking off my JVC television without the control, if so how?
Jan 10, 2014 | JVC PD-42X795 42 in. Plasma Television
Is the JVC AV-48WP30 VGA compatible?
Sorry. It can't be connected to a computer diretly. It is not VGA compactable. But if you buy one VGA to audio video converter, you can connect the tv in between. OK.
Mar 25, 2011 | JVC AV-48WP30 48" Rear Projection...
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
How do i get the cable to show on my tv it says no signal
do auto tunning,press menu & select tunning proses
Jul 09, 2009 | JVC LT42P789 42 in. LCD TV
How do you connect a dvd player to the back of the 42''JVC LCD ?
the directv needs hookedup to the tv, also the dvd player needs hooked up to the back of the tv, what type of cabling are you using, red/white/yellow or coax (where it screws in) or does it plug in and say hdmi, etc.
Apr 04, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC THD-50 system
Yes, that is correct. You can either use optical or digital for the audio to the jvc system. They give you 2 options but you can use either, they both work just as well.
Apr 03, 2008 | JVC THD-50 System
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
