Question about Miscellaneous
Keep saying empty fuel - Miscellaneous
  • uwbfritz Dec 29, 2016
    Hi Donna Farr, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is saying empty fuel? Make, year and model would be helpful if a vehicle.
My gas tank is on empty, but my "miles to go " on my dash is reading 300 miles til empty
Well, if you keep driving and you don't run out of gas. I would say the sending unit on the fuel pump is bad. And not reading how much gas is in the tank.
Oct 12, 2017 | Cars & Trucks
FUEL GAUGE PROBLEM
Sending unit in fuel tank--possibly
Oct 01, 2014 | 1999 Buick LeSabre
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
Fuel gauge says empty but tank full
yes it sounds right. unfortuneately the float is attached to the pump
Aug 13, 2013 | 2007 Dodge Nitro SXT
Just fueled up at the service station now the fuel guage keeps going up and down saying full then empty 2010 subaru impreza
Possible fault in the fuel guage float as it mught have got damaged and is floating according to the movement of the fuel in the tank than to float up.
Also it is possible that the fuel tank rheostat is faulty or the ground connection of the rheostat.
check also the dash cluster to the guage for any loose connections.
Oct 30, 2010 | Subaru Impreza Cars & Trucks
My fuel gauge says its empty
Your fuel costs too much, put more in it. Other wise, it probably has a faulty sending unit(sensor) Fill it up and see what it says then. Set your trip gauge and check the mileage or what ever u use there.
Feb 17, 2010 | 1994 BMW 3 Series
Fuel gauge keeps going to empty and warning light
in side the tank on the side of the pump there is what thy call a sender not to be confused with the sending unit. The sender is atached to the float and tells the gauge how much fuel you have.
Jan 05, 2010 | 2007 Chevrolet TrailBlazer SS
99 rodeo ran out of gas now no start
If you can hear the pump run and you get no fuel its the pump, If it blew the fuse i would say the pump tied up. That happens when you run around on empty a lot, gas is what keeps pumps cool when you run under 1/8 of a tank pump is not submerged in gas to keep cool hense pump burns up.
Mar 09, 2009 | 1999 Isuzu Rodeo
Open Questions:
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
