I wish to convert fission film strip scanner software to operate on a linux based laptop.
5 Suggested Answers
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
mohanchennai
  • 490 Answers
SOURCE: Stripline on my scanned images from Minolta 5400 II film scanner
If some particles of dust stick to the scanning module, then while scanning they appear like lines. Clean the scan module thoroughly using Isopropyl alcohol IPA-Industrial grade is enough, dont use any solvent. You can use your aftershave (!) once or twice. Ensure that the film strips are not sticky.
S. Mohan, Chennai, India
Posted on Nov 23, 2008
SOURCE: Epson 2450 Perfection Photo Scanner
The Epson film holders hold the film 1 mm (.039") above the glass scanning window. You could cut and glue 1 mm plastic sheets to make your own holder if you can't get the originals from Epson. I'm making one now that will hold more than a single frame of 120 film, which is all the original Epson holder would take.
Posted on Jul 20, 2010
  • 4 Answers
SOURCE: Where can I obtain software for my ION Audio ION
Download direct from ION Audio:
https://www.ionaudio.com/support/downloads/slides-2-pc
Posted on Mar 05, 2015
How do I find Fission Connect to freedom. workings to transfer slides into my Laptop. fission is suppose scan the slides, but I have no drivers.
I have spent about 30 minutes searching but there appears to be nothing. Connecting it to a modern PC may well find plug and play generic twain drivers which will make the scanner operate. You really need that CD from your late brother's collection of software CDs.
I did find the manual! Film Scanner Slide Manual Don't try the website as it is up for sale and anything advertised there is just spammy stuff.
Oct 03, 2015 | Office Equipment & Supplies
How do I load a driver for film scanner in ubuntu
search for <scanner name> ubuntu linux driver
Jan 24, 2012 | Canonical Ltd. Ubuntu
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Nov 21, 2008 | Office Equipment & Supplies
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
49 people viewed this question
k24674
