Question about SanDisk Sansa Fuze MP3 Player
How the hell do you reset this device? I have tried holding down all of the buttons and have also tried holding the power switch any help? PV2 Travis Davis U.S. Army Active Duty
    Problem Solver:
  • 5 Answers
Hold the power button for about a good 20 or 30 seconds
Posted on Jul 28, 2009
    Problem Solver:
  • 10 Answers
Go into Settings>System Settings, and scroll down until you see 'Reset Factory Settings'. Select that and you'll see a message asking if you want to restore all factory settings, then select 'Yes'. Then select your language and reigon, or press the 'Home' button and it'll land you back at the main menu. Hope this helps.
Posted on Jul 21, 2009
    Scholar:
  • 134 Answers
Pop out the battery if you can and wait a few minutes.
That resets all electronics.
Posted on Jul 23, 2009
ASUS ZENPAD 102300C AFTER CHARGING GOES BACK TO RESET
Have you checked for firmware updates? You can try to do a hard reset which can force OS errors to clear up.
First method:
  1. In order to switch off the device, hold down the Power button for a short while.
  2. In the next step press and hold Volume Up + Power key at the same time for a few seconds.
  3. You can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Factory Reset", and press Power button to confirm.
  5. Success! The hard reset has just been performed.
Second method:
  1. Turn on the device by using the Power button.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Tap Factory Data Reset and select Reset Device.
  4. If it's necessary enter the safety code and choose Erase Everything
  5. Select OK to confirm the whole operation.
  6. Well done! After a while your tablet should be ready to use.
Third method:
  1. At the beginning press the Power key to turn off your device.
  2. Afterwards press and hold Volume Up + Power simultaneously for about 5 seconds.
  3. you can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
  6. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  7. To restart the tablet, select "reboot system now".
  8. Success! The hard reset is done!
A Hard Reset will erase all of your data
Feb 16, 2017 | ASUS Computers & Internet
How do manually reset sansui lifepad to factory default settings
Try this:
1. Hold down power and volume up buttons for 10 seconds, then press volume down button.
Failing that, this:
1. Turn tablet off. Hold down power button until 'Device Option' menu appears.
2. Select 'Power Off' then 'OK'
3. When tablet has switched off, hold the 'Reset' & 'Power' buttons simultaneously for about 10 seconds.
4. Wait for screen display, then press 'reset' button.
5. The 'system recovery' screen should appear.
6. Use 'Home' & 'Menu' buttons to navigate the menu.
7. Select the 'wipe data/factory reset' option & press 'Reset' button.
8. Then select 'Yes- delete all user data' & press 'Reset' button.
9. Press the 'Reset' button to reboot/restart tablet.
Oct 15, 2014 | Computers & Internet
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
TOMTOM ONE -ABOUT 5 YEARS OLD NOT SHOWING ON LIST OF DEVICE, DOES NOT USE A CARD. PROBLEM-CANNOT SWITCH IT ON. Help!!
First, make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Sep 03, 2011 | Tomtom GO 910 GPS Receiver
Magellan does not turn on. Can we reset?
yes, you can try the reset but before you try that..plug it in to a known good charger (like the car charger has a green light to tell you its working)
once plugged in, press and hold the power button for upto ten seconds...if that fails, try the reset on the left side under the flap...depending when your 2200 was made, it will either be a pin hole where you can use a paper clip to reset it, or if its an early model 2200 it will have a slide switch that should be toward the down position..to reset turn unit on, then either slide the switch up, wait a second or two..then back to the down position then try and restart it...if its the pinhole, just depress the reset with a paper clip, then try and restart it by pressing and holding the power button for up to ten seconds.
these 2200t are also known to have faulty power ports that i can help you with should the above advice fails.
let me know if you need further help
bill
May 09, 2010 | Magellan RoadMate 2200T GPS Receiver
It Keeps Freezing up and i want to know how to fix it
Try this - Reset the device 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Or you can try to force MSC modes 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC. If none of this helps you might need to reload and update to the latest firmware or try and force recovery mode. 1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My Computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa Clip MP3 Player
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside (very small)
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I reset my iphone and now it is on black screen with apple
Hi Your iphone is having a software problem try to restore it whit itunes to the highest iphone firmware version, if your are still having problem send it to 1 iphone repair centre like www.E-Repairs.co.uk
Jul 04, 2009 | Apple iPhone Smartphone
Password locked on htc touch diamond
Do a hard reset. Press and hold volume down and center button and then press the red reset button behind the stylus. Cntinue holding the volume down and center button until the screen apperas with some message. Press vol up key now and let the device reset to the original factory settings..
N.B All your data and 3rd party apps will be lost
Oct 20, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Hawking wireless router to reset password
If you press the reset button you only make a reboot.
To reset all the value to the factory setting you have to:
- Power off the device
- Hold the reset button pressed
- While you press the reset button put the power back on
Now your gateway address is again 192.168.1.254, login is admin and password is not present (leave it blank).
Mar 01, 2008 | Hawking Wireless-G HWR54G (603992506064)...
SanDisk Sansa Fuze MP3 Player Logo
276 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
