Question about Brother MFC-J6720DW Professional Inkjet AIO w/11x17 Capability & Dual Paper Trays
I am trying to print some paperwork out on a brother MFC-J6720DW, but it is saying, unable to print 44 , what does this mean mean
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: brother mfc 240c error says print unable 51
Hi Ok try this it may work.
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Press 80
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
Shows print unable 4F
The LCD displays an error code with problem with Printhead. To fix Brother Printer Error Code 4f go through eh 2-3minutes read of blog either or connect o right experts for assistance. The causes to this error is connection failure of the carriage-head flat cable or head flat, Print head defective, Power supply PCB defective, Main PCB defective. Looks of the causes and move ahead with the issues. Brother to help you settle on your printer obtaining choice, read the Brother Printer Error Code 4f surveys and evaluations. Impart following Model Brother Printer such as:
    ·Brother multifunction printers
    ·Shading laser printers
    ·inkjet Printers When you are searching a Brother Printer answer for a home used or home office, little or medium business, or substantial business or workgroup, the impartial Brother Printer tech experts direct you towards the right printer solution. Connect to Brother Printer Support Number for proper and one to one assistance with experts.
Brother Printer Technical Support Blog News 1 800 213 8289
Dec 28, 2015 | Office Equipment & Supplies
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
I have a Brother printer MFC -J625DW. Error "Unable to Print44". Can anyone help me?.. Thank you
Machine error 44, indicates abnormal temp at Printhead, either the main PCB or print head is faulty.
Dec 27, 2013 | Brother MFC-J625DW Wireless All-in-One...
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Oct 15, 2013 | Brother MFC 6490CW InkJet Printer
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
Not printing. Says
Rather lengthy solution. Please refer to the link below for a description from Brother support: (basically some debris may be under the carriage path)
Brother MFC Unable to Clean Error
Jan 15, 2010 | Brother MFC-5440CN All-In-One InkJet...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-J6720DW Professional Inkjet AIO w/11x17 Capability & Dual Paper Trays Logo
23 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
