Question about Tally Office Equipment & Supplies
Tally 2250 no paper lading, control panel massage tractor 2, how to tractor 1, plz suggest
SOURCE: Hello this is relating to Tally 7.2
Solutions
In first case when data gets corrupted while working on tally and we are unable to open the company then data can simply rewritten. Come to Company selection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that
Posted on Aug 07, 2008
  • 114 Answers
SOURCE: tally 2250
switch off the printer then hold 1,2,3,4 key of the printer and switch on the printer dont lose those key the printer will show difault is loading. when the printer will go to the online then leave those key.
Posted on Jan 30, 2009
SOURCE: automaticaly close my tally 5.4
how many tipes of accounting
Posted on Jan 02, 2010
  • 29 Answers
SOURCE: i having tally 2250 printer. i have replaced the
may be your rga assembly having problem. check your ribbon gear is rotating or not.
Posted on Nov 18, 2010
SOURCE: Tally 2250 driver
i have tally 2245 some time work good and take the order to print but in the next order can not print..?can help me?
Posted on Mar 12, 2011
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
Tally 2250 gives error +0017
The error message given by the 2250 would be longer than given in the question. The whole error message gives an indication of what might be causing the problem. Some things you may wish to check include; Check the print head is free to move and is not jammed Check the carriage shaft is clean and free from any sort of lubricant Check the timing strip to ensure this is in possition and is not dirty or warn Check the paper path to ensure the paper is free to feed through the printer.
How to run tractor1 and tractor 2 Tally T2250 ?
The first thing you would need to do would be to ensure you have two sets of tractors. The second set of tractors is an option not on the standard printer.
You can fit the second set of tractors to the front or rear of the printer
You can select either of the two tractors in the following ways;
  1. Via the control pannel menu
  2. If printing from Windows by selecting the appropriate paper path when printing
  3. If you are able to insert control codes into your data stream you can use escape commands to change the paper path
Nov 30, 2011 | Tally T2245 Matrix Printer
What are the3 problem in tally 2250
main is initializing problem.....
paper sensor not working due to dust....
hp sensor problems....
Nov 03, 2010 | Tally T2250 Matrix Printer
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    Exiting Tally File: 'C:TallyDataTr01302.500 Size: 38784 Position: 38784 Chars: 128 (done 0). plz solve my problem to sawariiya@yahoo.com plz help me...........
    dear sir
    i have tally 9 v so my company data is not rewrite done
    on rewrite position show the massage of
    EXISTING TALLY
    INTERNAL ERROR CONTACT TALLY SOLUTION
    SOFTWARE EXCEPTION C0000005
    (MEMORY ACCESS VIOLATION)
    KINDLY PLZ GIVE ME THE SOLUTION FOR THIS PROBLEM
    THANKING YOU
    JAYESH KHARCHE
    jayeshkharche2007@rediffmail.com
    Nov 20, 2008 | Tally T2250 Matrix Printer
    Tally 2250
    Measure with a ruler the size of the form in inches that you are going to use .
    Calculate the number of lines you have by relating it to the Line Density using the formula
    Form Length = Form Size * Line Density
    For example for 11 inch paper at 6 lpi = 11 * 6 = 66 Lines
    You must disable the Printers Menu Lock before you can change any settings - (power on holding down SETUP)
    Press SET UP button on the Control Panel.
    Select the MENU Option on the Control Panel Display.
    Select the NEXT Option on the Control Panel Display until PAPER is displayed.
    Select the PAPER Option on the Control Panel Display by pressing the button directly beneath it.
    Select the Desired Paper Path for the Form Length change - The different Paper Paths can be stepped through by using the NEXT Option on the Control Panel Display.
    Select Paper Path by pressing the button directly beneath it.
    Select FORMLEN by pressing the button directly beneath it.
    Select LINES and then increase or decrease the value on the Control
    Panel Display by using the two arrow buttons until the desired length in lines has been achieved.
    Select the SET Option on the Control Panel Display by pressing the button directly beneath it.
    Set the Printer back ON-LINE by pressing the ON-LINE button.
    This will set the form length on the printer, see the support section of www.dascom.co.uk for more info
    Sep 18, 2008 | Tally T2250 Matrix Printer
    Solutions
    Jul 30, 2008 | Tally T2250 Matrix Printer
    24 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
