Question about Ovens
Hi i am cleaning the glass on my DC940 oven I have taken it out but now have a long metal grid and can't remember where it goes
    Top Expert:
  • Ovens Master
  • 41,919 Answers
The oven glass assembly is not intended to be removed and cleaned
Posted on Dec 20, 2016
Hi have taken screws out of oven door to clean on my Omega Oven & the whole front glass panel came off, can you please advise what glue is to be used to put it back on again please?
In my experience there is new glue used on oven doors. The glass has either a neoprene, woven glass matting or asbestos sealing gasket on the edges or both surfaces of the glass. The glass is put in place between clips/guides and then the door halves are tightened and it pinches the glass in place. The only glue-like substance you could use is Fire clay cement.
Jan 20, 2018 | Ovens
Noisy fan cda oven model DC940
Sounds like either your fan/motor has come loose or there is debris or junk in the moving parts.
Suggest remove the side panel and clear/clean the fan.
Be sure to disconnect the electrical power and stay conscious of the sharp sheet metal edges.
If this is an older model I suggest is time to purchase a new one.
Why ? Older models usually have other worn parts that will soon fail - after you do your marvelous fan fix a couple of months later the thing could give out wasting your time and efforts.
Nov 19, 2017 | Ovens
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
The inner glass for a Zanussi oven is missing. Is it possible to have this replaced?
Has the inner glass come away from the metal inner door?
If yes, then there are two ways to do this.
The first is to buy a new inner door and fit it to your outer door.
The second is to get a tube of high temperature sealant and repair the existing door.
To repair it you'd have to take the door off the oven and take it apart. Easier than it sounds.
Once the door is off and taken apart, it's a case of take the glass off, clean the glass and the metal, apply the sealant, place the glass on top and then put a weight on it for 24 hours to set.
Then rebuild the door and refit it to the appliance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 04, 2009 | Ovens
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
