Transmission wiring diagram-with wiring between trany and steering sector of vital importance
Color code needed to install backup cam
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
  • 61 Answers
SOURCE: Wiring diagram color codes for pioneer 6800mp cd player
what car is going into and in what country was the pioneer bought
Posted on May 15, 2009
rburroak
  • 14 Answers
SOURCE: wiring diagram (color code) Pioneer DEH-225
I went to the local sterero shop and they answered my question about the harness.
Posted on Jun 20, 2009
pops296
  • 174 Answers
SOURCE: need wire color code for ford F-250 tailer towing wiring
http://www.etrailer.com/faq-wiring.aspx. This has the hcarts to help you.
Posted on Oct 16, 2009
What is color of reverse wire on 2003 ram steering coloum
There should be no wires up there for the reverse of the trany just a cable and the switch on the trany controlls all the switching for the trany. It is called the nuetral saftwy switch mounted on the drivers side of the trany with a cable that moves it in and out of gear.
May 04, 2014 | 2004 Dodge Ram 1500
Hi i need help on timing marks for a golf gti 2.0 16v 1998 R reg need the orgainal marks as the cog moved and the mark has come off thanks danny email danny.millman@hotmail.co.uk
Heres a diagram which shows you how to line up the crankshaft on an auto trany or if it a manual trany and also line up the distributor, the crank diagram will list auto or mt this is for the type of trany as i said above, and the cam is also listed, hope this is helpful good day.johnjohn2_131.gifjohnjohn2_132.gif
Apr 17, 2011 | Volkswagen Golf Cars & Trucks
1971 ford f100 pickup neutral safety switch wiring color code
Ford Neutral Safety Switch; Ford Reverse Light Switch; Backup Light Switch.
The Neutral Safety Switch wires in my 1971 Ford F100 are orange with a blue stripe.
The Reverse, or Backup Light Switch wires are black with a red stripe.
There are two sets of two wires across this combined neutral safety and backup light switch, for a total of 4 wires. Photos are at the end of this post.
The switch for the 1971 Ford F100 pickup truck is the same as in many other years and models. For details, including parts numbers, see the following quote from an expert at Ford Truck Enthusiasts:
http://www.ford-trucks.com/forums/287185-back-up-light-and-neutral-safety-switch-2.html#post5601846
The neutral switch also controls the backup lights, and is the same 1967/77.
C7TZ-7A247-A .. Neutral/Backup Switch (Motorcraft SW-600)
There is no separate backup light switch..except on 1967/68 F350's.
Neutral switch location 1967/77:
The plastic half moon shaped neutral safety switch mounts on the outside lower portion of the steering column (NOT on the transmission!).
It's activated by an inverted Y shaped lever that snaps on the shift tube
D0TZ-7B097-B .. Lever, Neutral Switch Actuator = From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $18.72 / FTE member net: $13.23.
The switch is also still available from Ford, but the website is down so I can't post the list & net prices. .
1978 is the FIRST year the F100/350's have the neutral switch mounted on the transmission. __________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IMAGES
Driver side of the neutral / reverse switch showing the travel slot for the switch arm, the return tensioning spring, and the arm.
The front, steering wheel side of the neutral / reverse switch after removal from the steering column. The switch's two functions are actuated when the lever in the column moves the switch lever shown here to different positions as gears are selected.
The neutral switch is installed on the steering column near the firewall, with 5/8" bolts into the steering column (visible hole) and down column from a rectangular opening in the column housing. The actuating lever for the switch is attached to the gear shift shaft inside the housing; the lever is visibly protruding from the opening in this image.
Back of neutral / reverse switch, showing the wiring attachments. Black with red stripe is the backup light wiring, Orange with blue stripe is the neutral safety switch, it prevents starting in gears other than neutral & park.
Aug 03, 2010 | Ford F-100 Cars & Trucks
I have an 89 ford ranger that i have had to put two A4ld tranys into. I have no passing gear and an odd plug, help!!!! when the frist was installed by a transmission shop starts with an a and ends with co...
YOU NEED A ATSG TECHTRAN MANUAL WHICH IS A TRANSMISSION REPAIR MANUAL WITH ELECTRICAL DIAGRAMS WITH PRESSURE SWITCHES.YOU CAN GO ON LINE TO INTERNET FIND THE REPAIR MANUAL.ANY TIME WHEN YOU WORKING ON TRANSMISSION WHEN YOU HAVE ELECTRICAL PROBLEMS OR SHIFT PROBLEMS WITH 3 - 4 PRESSURE SWITCH.OR ANY SHIFT SOLENOID PROBLEMS A TRANSMISSION REPAIR MANUAL WITH ELECTRICAL DIAGRAM WILL BE HELPFUL.BUT GO ON LINE LOOK FOR ATSG TECHRAN AUTOMATIC TRANSMISSION REPAIR MANUALS. IT HAS THE FORD A4LD TRANSMISSION MANUAL.
Mar 07, 2010 | 1989 Ford Ranger
Honda 2001 error code P0740 problem Check engine light. What do I need to do correct it? How much will it cost me to correct the problem so i won't get rip off?
P0740 Trany converter clutch system failure
Since this is also a trany problem, test this code by getting a complete wiring diagram of the trany electronic circuit. Once you have it and identified the location and colors of the torque converter solenoids/module, it is a matter of measuring the resistance of the TCC solenoid and comparing it to all solenoids. If defective, it is will either show open or shorted connection. Don't forget the basics like checking the wires for integrity of insulation and routing (making sure the wires are not rubbing a metal or being burnt by the exhaust). If there is a chance that the solenoid needs to be replaced, drop the trany oil pan so you can verify for signs of debris.
TIP:
To manually test your TCC solenoid before replacing it, you can feed direct battery voltage on the supply side of the solenoid and you should hear it click. Also try to test the connections between the TCC module and the engine module.
Feb 06, 2010 | 2001 Honda Civic
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
Need radio wiring diagram (color codes) for a mercury mystique
I hope helps with this...
Good luck (remember rated this help).
Jan 12, 2010 | 1996 Mercury Mystique
I have a p0758 code I installed a new tranny I beleave my problem is at the computer where is the computer located so I can install a new one
P0758 is related to the 2-3 shift solenoid. Was the code present before the transmission was replaced? If not then I would definitely look for a solenoid or wire issue. If the code was there before but was not cleared after replacement, it may be a history code. Computer failures are relatively rare when compared to wiring and solenoid failures. Depending on your engine your module will be behind the left lower kick panel or under the left side of the insrument panel near the steering column.
VCM or Vehicle Control Module will need to be programmed when replaced. This is something you will need to have done for you at a dealer or repair facility.
Oct 31, 2009 | 2003 Pontiac Grand Am
Puttransmission in blazer 4wheel drive need
autozone sites has free diagrams,look online. or go to a napa store and theyll print for you. that sensor is the only 2 wire plug in the trans harness. it should be on the output of the transfer case
Aug 24, 2009 | 2000 Chevrolet Blazer
Transmission Won't Shift
The modulator is what tells the trani when to shift.. That is controled by vacuum presure.. Maybe check all the vacuum lines that lead from the trani.. Or It could be the mudulator or something else.. I belive there are some trani shops that offer free estimates..
Jul 22, 2009 | 2001 Subaru Legacy
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
