Question about Whirlpool LGB6300 Gas Dryer
You hold start botton it runs but no heat, you release start botton it stops
  • 585 Answers
Check the wires to the switch on the motor, or the switch itself is not "clicking". Unplug the appliance before removing any covers.
Posted on Jul 21, 2009
I have cat D399 wont start? when i crank it with air starter its run as long i hold the starter on whehn release the starter botton stopped?
if i remember right there is a solenoid valve on them when starting it has to be down for engine to start. if it fails it dont get the pressure needed to start. when engine is running and warmed up it opens. cannot remember were it is but I used to have one a long long time ago. and it was this fault.
Jan 02, 2014 | Caterpillar D399 Generator Drive Engine
Dryer will not run after completing a cycle without cooling down first
When it is not cooled down if you try and start it does it stop once you release the start button? Is the start switch by itself or with the timer? If it stops once you release the start buttong the most of the time its in your motor. The windings get hot and wear out. The options you have is if you hold the botton in will allow you to use it but eventually the motor will shut down. If you have any more questions or need help please comment me back.
Jul 27, 2011 | Dryers
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
The oven does not start
One of the interlock switches is defective or out of adjustment. By pressing the door release you were causing the switches to make or break briefly enough to allow the oven to turn on.
Jun 20, 2010 | Welbilt MR96TW Microwave Oven
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Whirlpool LER7646E will not stay running
I was told to replace the HEAT RELAY (3405281)or the Module Broad, but the problem is that 48VDC is not present on the motor relay.
Oct 12, 2008 | Whirlpool LER7646E Dryer
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
