I want my air condiner timer to go off
My air conditioner timer is blinking continuously so i want it to be off
  • 257 Answers
SOURCE: vw passat air condining not blowing cold air
It's very possible that the fan itself is bad - relatively common on VW's. First check the fuse for the fan on the fuse panel.
You could also have a fan control module problem. Can you hear/feel the compressor turn on? If so, then the module is good and you probably have a bad fan or a blown fuse.
Posted on Jul 10, 2009
  • 560 Answers
SOURCE: air condiner puts out warm air both sides
ck the a/c press. high /low if there close to the same the comp. has failed
Posted on Jun 10, 2012
  • 14 Answers
SOURCE: Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Posted on Jul 15, 2013
SOURCE: Mitsubishi Air Conditioner blinking Problem
Mitsubishi inverter timer flash
Posted on Jul 27, 2013
appliancexch
  • 448 Answers
SOURCE: Timer mode continually goes on and off by itself on kenmore air conditioner.
Change control board
Posted on Jul 03, 2015
Error e7 gibson air condination
Condination, wow that is an interesting spelling of the word Air conditioner.
Jun 23, 2017 | Gibson Heating & Cooling
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
My AC gets automatically turn it off and flashing timer bulb.
First check the following first.
1. Keep the temp between 24 to 20 degree celcious
2. Check the air filters are cleaned
3. Check the power is correct.. if there is fluctuvation use stabiliser or booster
4. Check condensor coil is cleaned.
Conclusion. Every a/c must be cleaned once in 3 months and air filters are to be cleaned by every week.
Sep 11, 2015 | Heating & Cooling
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
Air condiner puts out warm air both sides
Jun 10, 2012 | 1998 Buick LeSabre
Vw passat air condining not blowing cold air
Jul 10, 2009 | Goodman CKL24AR24 Air Conditioner
Split system wont cool
Check your service valve if open, check for kink piping or system clug up. But check also your refrigerant charge if adequate.by monitoring the suction pressure and current reading.
Mar 15, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
