Error occurred sc:390 function problem. Turn Main power Switch off then On
4 Suggested Answers
santosj27
  • 263 Answers
SOURCE: I have a ricoh 2051
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Posted on Feb 17, 2011
  • 525 Answers
SOURCE: Error occured SC:302 Functional Problem Turn
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
Posted on May 27, 2011
  • 1575 Answers
SOURCE: error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Posted on Mar 01, 2012
Code SC 390
SC 390 is a TD sensor code try changing developer (Type 24) B0649645 if not that then maybe the TD sensor pn#B2475310,
Mar 18, 2014 | Ricoh Aficio MP6001 Copier
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Error code sc 302
Hi
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Possible Cause:
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
Feb 17, 2011 | Ricoh Aficio 1035 Copier
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
What does the Functional Code SC 302 involve? Thank You! Jacque
This code refer to main charge.The charge corona leakage.Check the charge corone wire and grid (clean or change),clean the corona unit input contacts,check the main charge power pack and the high voltage control board.Recomand to change the corona holders,wire and grid.To reset the error code Turn OFF the power switch unplugged wait 10 sec plugged and turn ON the switch.
Sep 23, 2009 | Ricoh Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
