I am getting 2 error codes on my v20 I trane unit 184.07 and 184.08. What do these mean?
3 Suggested Answers
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
I have a Trane heat pump that shows error 79
79 i believe is a low pressure error code. This means you are low on refrigerant
Nov 12, 2016 | Heating & Cooling
My Trane AC thermostat (900 TOuchsreen) has an error code 126
Error code126 is equipment does not match value at startup. Usually a power surge or brown out can cause this problem. Turn power off to inside and outside unit, wait 5 minutes. Retry system.
Jul 15, 2016 | Heating & Cooling
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Error code 18 on Mitsubishi WS-55311
This is a V20 chassis, circa 2002
Available error codes for this unit are as follows:
12.....No error has occurred
21.....X-Ray protect circuit
22.....Short protect circuit
23.....Horizontal deflection failure
24.....Vertical deflection failure
Jan 07, 2015 | Mitsubishi Televison & Video
Trane xv95 converted to propane is on system lockout
There is either a problem with the ignitor or the flame sensor.
Nov 18, 2013 | Honeywell Electronic Programmable...
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
We were getting an E4 but now we get an E2 but
I do know that the owners manual should show you what each and every code means? Some times the manufacture will paste a strip located on the panel of the indoor unit showing what each code means. If not, I would contact the factory on this. I know on Bryant, Mitsubishi splits, Day and night, (Bryants), Tranes, Lennox and most all others, do show in the manual and on the unit behind the panel. Try looking for them there.
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Trane Furnace xv-80
check the pressue switch and make sure that nothing is in the fan that would cause it to not draw. I have seen water inside of them at times due to the high efficentcy of the units. let me know if this does not solve it please.
Dec 28, 2008 | Heating & Cooling
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
