Question about Dryers
Not spinning fan has power but won't spin
  • 65 Answers
Is ther a lille starter on the fan? looks like a other smal motor on the main one !
Posted on Jul 21, 2009
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Blower won't run
usually a "humming motor" indicates either a bad capacitor or a defective motor. With the power off try to spin the blower wheel...it should spin freely. If it is tight or wont spin and there are no obstructions stopping it (like an air filter sucked into blower or other debris) then the motor most likely is seized. If the blower wheel spins free then you may have a bad capacitor. Keep in mind, just because the blower spins easy doesn't mean the motor is good. I have had motors that are defective that dont seize up but most of the time the blower wheel will not spin free if the motor fails.
Oct 07, 2012 | Desa International Blower Glow Warm Wall...
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Why does my fuse for the radiator fan keep blowing
This is a sign that you have a power wire that is shorted to ground. First check the power wire leading to your fan to see if there is a possible short to ground. Sometimes if the wires are not secure, they can rub up against the spinning fan or melt against the exhaust, and then possibly short against the motor or frame. If the wires appear to be o.k., then check the fan motor to see if it is bad. Try spinning the fan blade manually and if it makes noise or won't spin, replace the motor. Once you isolate the short and repair it, you should be able to install a new fuse with no problem.
Sep 02, 2012 | 1997 Chevrolet Cavalier
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
PC Chips M860 mobo, won't boot, no beep. What are the likely problems?
If the fan of the processor is not spinning that means that your processor have a problem. If the CPU fan is spinning and after a second it stop that means your processor is defective
Sep 03, 2011 | PC Chips MB PCCHIPS K8T800 M860 V1.0...
POWER TURNS ON AT THE CONDENSER MOTOR, BUT IT WON'T START RUNNING UNLESS I START SPINNING THE BLADE ON THE MOTOR WITH A SCREW DRIVER.
If it spins freely when it is not powered then the start capacitor has gone bad and replacing that will fix the problem...
If it does not spin freely and the bearings need oil then check out this tip on how to oil the bearings in the motor...
How to Oil Condenser Fan Motor with pictures
heatman101
Aug 06, 2011 | Carrier Heating & Cooling
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
Dryers Logo
106 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
