Question about Refrigerators
FREEZER WORKS PERFECT BUT THE FRIDGE IS NOT COLD LIKE INITIALLY. CHECKED THE EVAPORATOR FAN . IT WORKS PERFECTLY. SWITCHED THE FRIDGE OFF FOR 24 HRS,TURNED ON BT SAME PROBLEM?
DEFY640SS FRIDGE
  • 103 Answers
The gas may be leaking
Posted on Dec 20, 2016
Neff Fridge Freezer K3965 Freezer is working but the fridge is not
This is either a defrost problem or the evaporator fan is not running. The way to check is to open the freezer and do two things. Listen to see if the fan is running, if not and you hear the compressor in the back going then the fan is the problem. If the fan is running then look at the freezer wall and see if it is covered in frost. If so, you have a defrost system failure and either the timer, bi-metal or the defrost heater has gone bad.
Sep 05, 2012 | Neff K3965XO Side by Side Refrigerator
I have a samsung RS21DCSV/X FRIDGE FREEZER.THE FREEZER WORKS PERFECTLY.BUT THE FRIDGE WILL ONLY COOL TO 13 DEGREES
Initially, pls check the:
  • thermostat and its setting for the fridge part;
  • check if the fan is spinning to draw cold air from the freezer towards the fridge portion;
  • check if any food stuff is blocking the fan/vent;
  • on instances where a large number food stuff has just been placed inside, it may take some time for the temp to go down;
  • see if you have a turbo cool and enable it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Freezer works perfectly...fridge just stopped being cold..
Do you hear the fan in the freezer ? If not , then your evaporator motor is the problem . If fridge gradually stopped getting cold , then possibly defrost problem which is another route .
Jul 11, 2009 | Maytag MFD2561HE Bottom Freezer French...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Maytag MBB1954GES not cold. Fresh food area warm, motor not on. Freezer OK.
Check the freezer fan is running with the door switch pushd in by hand, check the back wall of the freezer for frosting if it's frosty check the defrost system eg defrost element, Defrost termination stat and defrost timer. If the freezers running perfect check the fridge difuser/damper and see if it's open this is the part that opens and closes the vent between the freezer and fridge to allow cold air into the fridge. The Damper is up the top left corner of the fridge. cheers.
Mar 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Freezer cold but fridge warm
Hi and welcome to FixYa,
Initially, a couple of possibilities you may want to check, consider, try:
  • evaporator fan - purpose is to draw cold air from the freezer and blow it to the refrigerator section. This is actually what cools the fridge side. A test is to open the door, press and hold on the door switch, light should go out, fan should come on after a minute or so. If not, possibly a defective fan (most likely) or faulty controller (least likely);
  • thermostat - this is both a sensor and a switch. It sets the coldness level of the fridge area. Once it senses that the fridge temperature is relatively high, then it triggers the controller to engage the compressor and kick in the evaporator fan. A continuity where its resistance would change depending on the ambient temperature;
  • controller board (a possibility) - as the name implies, it controls the functions of most (if not all) of the active components of the refrigerator/freezer. It receives input from the different sensors and reacts accordingly by switching other components on/off.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Moved The Fridge, Not cooling
Check the evaporator fan inside the freezer compartment.
Dec 23, 2007 | Amana ABB1927DE Bottom Freezer...
Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
