Question about Plumbing
How do you install the hose to the faucet
How do the brass furrows work
3 Suggested Answers
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
SOURCE: How do I get an
I went to OSH hardware. I unscrewed and took the portion of the faucet- that the hose from the steam cleaner was to fit into and I took the hose right into the store. I just bought my unit at the thrift store. Works great. I love it!
Posted on Jul 14, 2011
The hose to a faucet sprayer has been cut away but is still connected to the faucet, will this affect the flow of water to the faucet if so how do you have to remove the rest of the hose?
iF YOU NO LONGER WANT A SPRAY HOSE, SIMPLY UNSCREW THE HOSE IN A COUNTERCLOCKWISE DIRECTION. a 1/4" BRASS CAP OR AN 1/8" BRASS PLUG IS USED TO PLUG THE HOLE. uSE TEFLON TAPE ON THE THREADS.
Sep 09, 2017 | Plumbing
I see hose repair parts in house and garden stores. How exactly do they work?
Hi Colleen:
Easy as 1-2-3
1- Cut off the bad fitting
2- Slip the clamp over the hose and push the replacement fitting into the hose
3- Align the clamp and tighten it.
Back to the garden!
May 21, 2015 | Garden
I recently installed a Pfister Cagney Single control kitchen faucet with side spray. The spray has no pressure. The water from the faucet is great. What could be the problem?
Could be trash got into hose( i.e., teflon tape, brass shavings, etc.). I suggest that you turn off water, disconnect the hose and try flushing water through the hose with no sprayer attached. If water goes through, then you have a stoppage in the sprayer. The face of the sprayer usually unscrews allowing you to check if there is trash in it.
Apr 09, 2015 | Plumbing
How do I get an adapter for the faucet for my Bissell 1631 Power Steamer. The brass fitting on the end of the water hose does not fit the faucet. I need one that I can add to the current brass fitting so...
Jun 27, 2011 | Bissell 1631 PowerSteamer ProHeat Canister...
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: FortĀ® Single-control...
I need to replace a brasscraft compression valve G2CR19X C1 how do I remove the brass fitting and nut that goes around the plastic hose that comes out of the wall and plugs into the toilet.
usually if its leaking and you have the same replacement then just reuse the compression nut and furrow and it doesn't hurt to use a little pipe dope or just unscrew the packing nut and change out the the valve stem
Sep 11, 2010 | Timemist 383081TM01 Plumbing Replacement...
How do I remove the spray hose from the brass connector under the sink?
On the side of the brass there should be a clip or a pin that you can pop off... a knife or screw driver will work to snap it out of there... then the hose will just pull down out of the fitting...
heatman101
Sep 03, 2010 | American Standard Kitchen Faucet 6310 020...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
How do I take my faucet off? It's a Grohe Lady Lux. We are trying to replace.
You need to remove the sprayhead and hose from faucet and underneath you will see a brass threaded tailpiece that the mounting nut is connected to you need to turn the threaded piece counter clockwise.The faucet came with a paddle handle tool that fits in the brass tailepiece but I have used a basin wrench carefully to loosen without damaging threads
Nov 14, 2009 | Plumbing
Plumbing Logo
89 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
