Question about Air Tools & Compressors
Got a Bostitch 3 gun set and cant get any of them to shoot straight out of the box.
comax
  • 154 Answers
SOURCE: Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Posted on Apr 13, 2009
Editor925
  • 285 Answers
SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Posted on May 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: bostitch n80sb 1 framing nail gun shoots 2 nails
I would think a part other than the magazine. I would first check the condition of the nose to make sure it is not just worn out. Also check the driver for the end being flat and the back side (toward nail)not worn excessively and lastly check the O ring on the piston. Starting with nose unplug air and look to see if oval and then bounce the tool without air and see if the piston drops from the rest position. If so that is where I would start. Let me know if something other than this and I will try and help. I have worked on quite a few of these. If I have helped you would you please rate my response accordingly. Thank you
Posted on Jul 16, 2009
  • 6 Answers
SOURCE: Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Posted on Feb 01, 2010
SOURCE: nail gun not putting nail in all the way
you need to disassemble de gun,
once you take the rod that pushes the nails. you'll see that at the end of it its threaded that is the adjuster
you just turn it the way it needs to go. it is pretty simple what takes you more time is the disassemble process and of course putting everything back together.
Posted on Jul 26, 2012
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
The nailer is jammed but it is not in the shaft, how can I unjam this gun?
Clearing the jam will require some disassembly. See the link below for additional information about parts and disassembly diagrams for Bostitch guns. Enter the model number when asked.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Feb 25, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
Bostitch n88rh, driver won't retract, does so after disconnecting air, shoots 2-3 nails then same problem, thanks
Have you put oil in the air chuck inlet lately to lubricate? Let me know if this helps or we can investigate further
Jan 20, 2011 | Stanley Bostitch Nail Gun
Only shoot out one nail and get stuck. The pusher pin get stuck.
more than likely, it just needs oil
the gun should have come with a bottle of gun (pneumatic too) oil. You'll need to over oil a little at first with about 8 drops, then about 3 drops EVERY time you use the gun
Oct 24, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
The gun is difficult to get to shoot. you have to wiggle it and push the nail down to get it to shoot
Unfortunatly that is a common problem for those nailers. If you replace the contact housing assembly,that usually fixes the problem. P/N 174084 Bostitch service center will have the proper parts.
Oct 22, 2009 | Stanley MCN-150 Bostitch Strapshot Metal...
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
Aug 21, 2009 | Stanley Factory Reconditioned Bostitch...
May 31, 2009 | Stanley Bostitch F21PL Nailer
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
