I have no sound card - Computers & Internet
How to install a sound card
1. Locate na expansion slot in your computer that will accept your sound card.
2.Gently place the sound card on top of the slot. Line up the pins on the sound card with the slot and push the card down so that it sits in the slot. Be sure that the card is securely in the slot and pushed all the way in.
3.If your computer has an audio cable that connects the CD-ROM drive directly to the sound card, locate it and plug it in to the card. Consult the documentation that came with your sound card to determine the location of the CD-ROM audio connector on the card. This cable is rarely necessary with current audio hardware.MORE INFO.IN NEXT SLOT
Apr 04, 2010 | Creative Labs Sound Blaster Live! 5.1...
How can i find my sound card?
There are 2 ways to find your sound card driver
  1. you see the chip on your sound card where driver model write on chip.
  2. You download driver detective and install in the system.
Then you can search the sound card driver.
Mar 13, 2010 | OEM Systems OEM: 32-bit PCI CMI8738-6 5.1...
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
No sound drvers install in may pc
your sound card not adjusted/inserted properly.
if insertef properly then your sound card not support your motherboard
or insert into another slot sound card may be that is not support.
2...if your sound card is built in motherboard then may be your driver is not support to sound card.tell me about your sound card company.
i provide more sollution you. thanks
Apr 08, 2009 | Compaq Creative Sound Blaster PCI 128...
Sound card driver
You should be able to get the driver from the Compaque website by submitting the model of your computer.
Nov 29, 2008 | Compaq Creative Sound Blaster PCI 128...
Sound card, multimedia card, tv tuner card.
sound cards are card fitted in pc to get sound when soundc slot of motherboard is malfunctioning or driver is not available,multimedia cards are cards for storage connected through USB and display cards are used when video slot of pc is malfunctioning or there is no driver.higher memory display cards are known as graphic cards.
Sep 28, 2008 | Compaq Audio card Sound Card
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Aug 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound card driver
Linked above is the download page for all Creative Sound cards. Choose your model sound card and it will take you to a download page for drivers with all supported OS's, including XP
Good Luck
Jun 27, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sound card driver
we lost the driver of our sound card card Trident 4DWAVE-DX. we cant locate the product in the internet.pls provide us the driver for this sound card.tnx
Oct 31, 2007 | Trust Sound Expert Digital Surround 511...
Can't find driver for sound card
you may need to go into the bios F2 or Del on boot up and in advanced cmos settings look for onboard sound and select dissable if you are refering to a seperate pci sound card.
Sep 16, 2007 | Intel Mackie UAD1 Powered PCI Plugin for...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
