Question about Miele Dishwashers
Getting a FOE error code on a Miele G7859 can anyone tell me what this error code is?
3 Suggested Answers
SOURCE: MIELE G7859 DISHWASHER FAULT CODE
Hi .....F26 means the flood switch within the base has been activated ..........ya need to rmove base and raise of the floor and test on cycle looking for a water leak.
Posted on Jun 11, 2008
ZJLimited
  • 17970 Answers
SOURCE: Have just bought a secondhand
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
Posted on May 20, 2011
Where can I find the service manual of a Miele T4662C dryer ?
Error codes are here
http://appliancehelponline.com/miele
Oct 19, 2015 | Miele Dryers
Spa builder spa error code 126
Those are not Common Error Codes, Is it possible that the codes are characters other than the numerals you posted 125/126?
Jul 17, 2013 | Spa Builders Pool & Spa
F35 ERROR CODE
had exactly the same thing happen; did you figure it out?
Would like to know if you had a big fee as won't bother if it is expensive to fix! Thanks Emma
Jun 16, 2013 | Miele KM 5753 Stainless Steel Electric...
MIELE G7859 DISHWASHER FAULT CODE F04
MIELE G7859 FAULT CODE F04 INDICATES A FAILURE OF THE TEMP SENSOR
Jan 16, 2012 | Dishwashers
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
MIELE G7859 DISHWASHER FAULT CODE F26
Apr 23, 2008 | Dishwashers
Got a Miele G2220sci dishwasher unit, getting an undocumented error code of F19 with flashing lights, help! what does F19 mean?
Miele tech's say this is a "Flow Meter" problem, which could involve their service department.
Apr 06, 2008 | Dishwashers
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Miele GS2220 Sci error message F84
Call Miele they will send a copy of the instructions booklet, I did and I got one
Nov 18, 2007 | Miele Premier-Plus Built-in Dishwasher
E90 Error Code
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
Dishwashers Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
