The sistern is running al the time - Office Equipment & Supplies
  • 103 Answers
If it is running inside flush then a washer at the inside bottom needs replacement. If it is overflowing the tree float valve needs change.
Posted on Dec 20, 2016
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
Carbs need removing & the float jets cleaning, there is some debris stuck between the needle valve & the holder.
Easiest way to explain , it is like a toilet sistern float.
Sep 07, 2011 | 2003 Honda VT 750 C2 Shadow
My 2500 chevy pu has no day time running lights now no power at the bulb but has power at fuse pannel
It sounds like your day time running light relay is not functioning. The relay is located under the hood on the drivers side labeled day time running lights. to test you can just swap it out with the high beam relay. If your day time running lights then come on al you have to do is install a new relay. good luck
Jul 18, 2011 | Chevrolet 2500 Cars & Trucks
Water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Jul 12, 2010 | Eljer Toilet Onepiece Canterbury ...
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
Jul 12, 2010 | Mansfield Plumbing Products Mansfield...
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the...
hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Jul 05, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I installed the 1.6 gal Maxima EL.\r\n I placed
Hi im Rossouw
put 4 clouse cuppels in today hehe
Step 1, place sustern on boul. tight it up and muve the sustern attached to the boul flush with the wall.
step 2, mark out were ur toilet will stand with a pensel, then remove pot and apply silicone to pot base [Remove sistern first lol] and to the floor were the pensil mark is
Step 3, ones ur pot is on the floor put ur sistern on. i think the leak you were refiring to is the spunge rubber in the middel of ur sistern, make sure that it is furmly over the thred on the out side of sistern were flush meganisem comes out and tight it all well down. check ur pot with a level and if it is let it dry over night and then u can use it
plz rate my advice
Jul 02, 2010 | Jacuzzi Bath Maxima EL61 959 White...
I want to install my AL-1530CS with my new HP Laptop 64-bit running Windows 7. Where do I get the correct driver?
There are NO Win 7 drivers, and I suspect there never will be. Sharp are NOT writing a Win 7 driver, for this "Old", according to Win 7, hardware. You may be able to install a, XP SP2 or Vista 64 bit driver, and setup in Compatibility Mode, however if you do,do this EVERY-TIME you Bootup you MUST press F8, and select to Disable "Digital Signature Checking" at bottom of list. You need to do that at install time too.
Feb 22, 2010 | Sharp AL-1530CS All-In-One Laser Printer
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
I have a Sharp al 1010 that is always indicating the toner is out, even though I replaced the cartridge with a new one (twice..thought there was an issue with the toner cartridge). Also recently replaced...
if you have replaced the toner unit the main cpu is bad not realLY worth fixing but this is a very good copier you can get them on ebay , this the only copier you can refilll the toner unit for $6 & DRUM FOR $15 get a AL1655 best deal
Mar 03, 2009 | Sharp AL 1215 Black and White Copier
23 people viewed this question
