Question about Home
When starting my pellet stove the entire house fills with smoke before fan comes on
I have a multi fuel stove made by us stove. When we try to start the stove the enire house fills with smoke before the fan sarts. It smokes so bad the fire dept. got called twice. Now I noticed a large crack in the stove in the front through the cast iron. It must have been a flaw because there is no way it could have gotten cracked.
  • 5911 Answers
SOURCE: cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Posted on Feb 16, 2008
  • 36 Answers
SOURCE: When I first noticed a
the turbo is faulty and leaking oil into the exhaust system
Posted on Jan 08, 2009
  • 226 Answers
SOURCE: Smoke out of exhaust and loss of power
this sounds like antifreeze entering the crankcase..blown head gasket .warped head . cracked the block . pray it's only a blown head gasket and get it checked for cracks and straightness with a new head gasket might be all that's needed. the high pitched whining noise was probly your waterpump spinning dry . might need a new water pump to (where is your coolant lvl and what is the strength of it for the cold weather)
and a few exaust doughnuts wearing thin letting smoke out in the engine compartment not healthy to breath you should get it looked at.
  • 70 Answers
SOURCE: portable heater blowing smoke on start up
Sounds like it is not burning all the fuel . If you have the manual it should tell you how to adjust air flow so it will burn wright. You might need to clean the nozzle that the oil comes out of. The manual will have the cleaning steps to if you have manual. If not i can try an find one for you.
Posted on Jan 18, 2009
  • 247 Answers
SOURCE: Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Posted on Mar 19, 2009
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
Nov 28, 2017 | Heating & Cooling
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
When I light my pellet stove and push the start button the exhaust fan comes on but the smoke in the stove don't blow out the exhaust. What could be the problem?
Are you sure it is the exhaust fan and not the convection fan or the fresh air fan you hear? If it is the exhaust fan, check for blockage in the exhaust pipe.
Feb 22, 2016 | Whitfield Advantage II-T Service Manual
What is causing the ready light to flash red twice when I try to light my pellet stove
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
Pellet stove does not light how do you get it started to light up the flames.
I will assume that you do not have an electric starter on yours...
So you fill the pot with pellets and then use a product like this to help you get the fire started...
You can do it by using newspaper or wood chips, but it is much more difficult...
Sep 26, 2011 | Napoleon Auburn Pellet Stove Heater
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
I just got a Whitfield Quest pellet stove from a friend. Do I need a fresh air pipe if I use it in my house/ basement? Also where can I get a repair/owners manual. Thanks Kurt Willem
Some people plump in fresh air but you can also punch out the fresh air in take out on the back of the stove and recirculate the air within your home.I would think twice about installing it in your basement . Basements have a tenancy to create a negative pressure, which means that it can become very difficult to create and up draft through the chimney , which causes the smoke to seep out of the stove into your home. The only way I have found to over come this is to run a torch in the stove for 5 mins before starting a fire, this creates an up draft which eliminates the problem.
Aug 19, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
