Question about Staples Office Equipment & Supplies
Staples (SPL-EXC8A) won't stop running even when on automatic
    Top Expert:
  • Staples Master
  • 44,073 Answers
Check for a blocked sheet sensor under the loading slot
Posted on Dec 20, 2016
Staples shredder spl-exc8a
Such appliances often have one or more hidden screws, hidden by control knobs/switches, rubber feet, stuck on labels, plastic plugs that need drilling and so forth. It is usual to find at least one screw is anti-tamper and needs a driver of an unusual pattern.
Dismantling many modern appliances need detective skills...
Domestic standard shredders produce a lot of dust and small paper pieces that must be periodically cleaned out if efficiency is to be maintained and paper is very abrasive and soon dulls blades causing the motor to need to work harder.
Once cleaned out a brief spray with a silicone dry lubricant will restore performance but leave it for a while after spraying to allow the flammable propellant to disperse.
Dec 01, 2017 | Staples Office Equipment & Supplies
STAPLES SPL-TMC 12A SHREDDER
There is an optical sensor that needs to be cleaned. It is usually at the middle of the slot where you put paper to be shredded. Use canned air to blow out both holes (one on each side of the slot).
Hope this helps.
Sep 22, 2016 | Staples Office Equipment & Supplies
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Auto setting will not work on Staples SPL-EXC8A
Cleaning of the paper sensors is essential. Blowing on the center of the paper insert area will clear the paper fibers near the sensor but not all. Since my shredder was way past warranty, I opted to remove the 7 screws on the back of shredder mechanism, gingerly remove the shredding mechanism from its seat and there I found, wedged in between one of the sensors, a solitary paper fiber. That ominous, evil paper fiber was wedged in so tight that even the jet engine blasts from a 747 aircraft would have not dislodged the paper fiber. Making use of a Qtip, I dislodged the paper fiber, cleaned out all remaining paper fibers in and around the inside of the housing, then reassembled the unit. It has worked satisfactorily since then.
Apr 24, 2012 | Aurora Electronics AS1018CD Shredder
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
124 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Terry Hair
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
