Question about Murray Garden
Information on twin cylinder 18hp motor mounted in a Murray ride-on 18ic/46
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Murray Master
  • 975 Answers
Something specific? there is a lot of information.
Posted on Dec 21, 2016
We replaced the deck belt on our 18hp 46 cut Murray and now it keep coming off. No model #
either you got the wrong belt or the tensioner pulley is not spring is not set correctly
Oct 15, 2017 | Murray Garden
18hp Briggs & Stratton twin cyl, vertical crank, built into a Murray ride-on mower 1996 model 18ic/46. Where can I get info on this?
There is a hole through the pulley that the crankshaft goes through and is keyed with a square key stock, from underneath you will insert at least a 6 inch extension with a 5/8 socket on the end, the bolt will turn counter clockwise, it is fine thread so do not misplace it. Some times some oil and heat is needed to get the pulley loose, I unbolt the engine from the tractor and jerk it straight up as hard as I can and as many times as needed to get it off. Try not to bend the belt grooves with a hammer and pry bars as they are not all exactly the same and can be a chore to find another one.
Dec 20, 2016 | Garden
Where can I download a repair manual for a 46 cut 18hp murray riding mower?
http://lawnandgarden.manualsonline.com/manuals/mfg/murray/murray_lawn_mower_product_list.html
Nov 28, 2015 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
I have a Murray 17.5 HP Twin 46" automatic drive riding mower that only moves very slowly. What are possible causes?
If the transmission is hydrostatic and has some hours on it, the transaxle may be going bad. If this has been getting worse as you use it. If the problem happened suddenly, could be a belt loose or stretched.
Jun 26, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Apr 19, 2010 | Briggs & Stratton Power Products 1539...
Need older 18hp b@s hrizontol shaft motor
If you don't run it any longer you make be able to replace the connecting rods and clean the aluminum from the rods off crankshaft with a very fine emery cloth. A clyliner hone and a new set of rings would also be needed.providing the cylinders arent scored. A gasket set and parts would probably set you back about 100 to 150.
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
