Question about Kyocera Mita KM-2550 All-In-One Laser Printer
MY KYOCERA 2550 PRINT OUT BLACK I CLEAN THE CHARGER
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
This - two- reasons 1- the corrona on the top of drum unit is very dirty or its connection point are dirty with toner . just clean it then replace it again .if that not help you ll need to chick the corrona board
Posted on Mar 16, 2017
2 Suggested Answers
SOURCE: Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
Posted on Feb 06, 2009
The kyocera km-2550 is giving me an error "Print Mode Erro"
go to printer properties, printing preferences and set the paper size to A4 or the size you are sending
Sep 07, 2010 | Kyocera CS-2550 Black and White Copier
Blank copy
please check corona wire may be it was broken re-wear it then print ok
Nov 21, 2009 | Kyocera CS-2550 Black and White Copier
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
How to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Sep 29, 2009 | Kyocera CS-2550 Black and White Copier
I'm try to print a PDF file by Kyocera CS-2550 but after i press print button it's not print and in the kyocera screen I see Print Mode Error
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 16, 2009 | Copystar CS-2550 All-In-One Printer
Black line on print-outs
When u found any extra black or white vertical line, we can check 3 possibility:
1) check the toner container. U may have to replace a new 1 if necessary.
2) clean the charger wire. Just slide the Charger Cleaner (green color) backward and forward 3-4 times to clean the charger wire, then return to its original position.
3) check the charger cleaner is it in its original position or not?
YBC (/\)
Jan 21, 2009 | Kyocera FS-920 Laser Printer
Scanner password
HI there try the following.
  • Open Internet Explorer
  • Type in the address bar the IP address of the scanner (If you do not know this print out a status page)
  • Once you have typed in the IP address you will then have the scanner configuration screen on the left you should have passwords section you will be able to change it from there.
Hope this helps you
Thanks J
Jan 14, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
54 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
