Custom print settings - Office Equipment & Supplies
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
I am too stupid to print an envelope
No, your not. The M24 has to be the hardest machine on earth to print an envelope on, It is the biggest headache I have ever seen in printing. Here are the instructions and good luck.
NOTE: The PCL driver is the only driver supported for printing envelopes. There is no support for printing to envelopes using the Adobe PostScript® printer driver. It is necessary to complete all steps to successfully print envelopes.
NOTE: If printing through a server, changes to the driver must be made at the server level.
To set up the custom size paper for the printer:
NOTE: The setup of the custom size paper is a one-time step. Once the custom size is setup it remains an available paper size until it is changed.
  1. At the workstation, click on [Start], point to [Settings], then select [Printers].
  2. Right-click on your printer and select [Properties] from the menu. The Printer Properties window will be displayed.
    NOTE: Use the custom size paper in the printer driver when printing within an application.
  3. Select the [Configuration] tab.
  4. Select [Bypass Feed Orientation] and make sure it is set to Portrait in order to feed the envelopes long edge feed (LEF).
  5. Select [Custom Paper Size].
  6. Select one of the five custom sizes.
    NOTE: There are five custom sizes that can be set up for use in the printer driver properties. Custom Paper Size can be given an individual name by selecting [Name]and typing the name for the custom size, such as, envelope. The name will then appear as an option in output size.
    Three types of envelopes are supported:
Type for Envelope Metric Size Imperial Size Monarch 98.4 mm x 191 mm 3.9 x 7.5 Inch Commercial #10 105 mm x 241 mm 4 x 9.5 Inch DL 110 mm x 220 mm 4 x 8.6 Inch
  1. Enter the short edge and long edge values for the envelope size you are using. The driver will now show the new custom size as one of the choices in Output Size.
  2. Click [OK].
To set your printing preferences for the printer:
  2. Right-click on the printer you want to print envelopes and select [Properties] from the menu that will be displayed.
  3. Select [Printing Preferences].
  4. Select [Tray 5] (Bypass) for the Paper Source.
  5. Select [Heavyweight 2 (170-220 g/m²)] for the Paper Type.
  6. Select the custom size you created for envelopes for the Output Size.
  7. Click [OK] twice to exit the Printing Preferences and the Properties windows.
To print envelopes at the workstation using Microsoft Word®:
  1. Open your Word application.
  2. Select [File] on the top left of the toolbar.
  3. Select [Print] from the menu. The Printer window will be displayed.
  4. Select the printer that you will use to print the envelopes. This printer will use the same driver where you defined the custom paper size.
  5. Select [Close].
    NOTE:If you do not select the correct driver you will not be able to select the correct paper size in Page Setup.
To print envelopes at the workstation using Microsoft Word Page Setup:
  3. Select [Page Setup] from the menu. The Page Setup window will be displayed.
  4. Select the [Paper Size] tab.
  5. Use the paper size pull-down to select the paper size you defined in the driver. The paper size will be listed by the name you gave it in the driver setup. The default will be custom 1, 2, 3, 4 or 5.
  6. Make sure the orientation is set to Landscape and select [OK]. At this point edit the page with the information you want printed on the envelope.
  7. Select [File] from the toolbar.
  8. Select [Print].
To load envelopes at the printer:
Load the envelopes into Paper Tray 5 (Bypass Tray). The orientation needs to be long edge feed (LEF) with the flap closed and the flap side at the lead edge, and the print side facing down. The printer is now set to print on the envelope.
NOTE: Load a maximum of 10 envelopes into Tray 5 (Bypass Tray) at a time. You may be able to fit a few more depending on the envelope's thickness but do not exceed the max fill line on the tray. The envelope may wrinkle depending on its weight and stiffness. The machine is not designed to handle high-capacity production envelope printing.
Feb 09, 2009 | Xerox WorkCentre M-24 Color Copier
Printing a custom page size
On the page to be printed. Click File > then click on Print > Click Properties to check Paper Size for printing output. Or you can go to Print Preview first adjust the settings/properties in there before clicking on Print for the final print/output.
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Can not set custom paper size in HP C7180
I had to seek Help several times, and then work through the steps a few times before I learned the overly complex HP method for setting custom sizes (I never thought I would have anything good to say about Dell printers, but it was MUCH easier to set custom sizes on my old Dell than on this HP C7180).
Anyway, it sounds as though you are nearly there. After you set the size and save the name, you must click OK, then click OK in the Document Properties window. Then close any open windows, like "Document Properties" or "Print Pictures", and start over from "Pictures" or whatever photo browser you are using. Chose an image and click "Print". Under Printer, chose "C7100 series", not "...series fax". Under Paper size chose "More". Your new custom size should now be the last size listed (although, it has shown up as the first size a couple of times, ...go figure). BTW, I am using Windows Vista.
Hope this helps.
Nov 23, 2008 | HP Photosmart C7180 All-In-One InkJet...
Hp c4180 custom envelope size problem
Please try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01518768&cc=us&lc=en&dlc=en&product=1141647.
If not open solution center> Setting> Printer Settings> Print settings and you will find a custom option there and then create a new size and give it a name and when you print from any application you will see the new size reflection in the application( i.e Microsoft word or excel) you are trying to print from.
Good Luck
Jul 13, 2008 | HP PhotoSmart C4180 All-in-One Color...
Epson Stylus Pro 2200 printer help
I have the same problem with custom sizes. Also, some sizes are unavailable. I did get a custom size working by setting the margins to .25,.25,.25,.45,
Apr 13, 2008 | Office Equipment & Supplies
Setting Usier defined paper size
Hey osmund, You want to use your paper size which is 8.5 x 13" but in the custom paper size you are finding 8.4 x 14". Am I right. So, where is the problem my dear. Be sure, that your document size is in 8.5 x 13". Give Print command with custom size, it will print on that size you want.
Apr 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
23 people viewed this question
k24674
