Question about Toshiba Satellite 1905-S277 Notebook
I decided to upgrade the hard drive to a Western Digital 250 Gig from the original 30 Gig. I also added the RAM module-- making it 512 now. The problem is that after loading the original restore CD's that came with the computer-- when I click on "My computer"-- right click-- and check the properties of the C drive, it says there is only 127 Gig available. I've talked to a few people and they told me I had to update the BIOS. I did--- I downloaded to a floppy from the Toshiba website, version 1.4-- it still says 127... then I re-formatted-- again.... and it STILL says 127 Gig available.... I've been reading some chatter online, and some people are saying that messing with the BIOS has messed up the computer... so I am a little gun-shy to continue now-- because it is still working-- as far as I know.
    Scholar:
  • 122 Answers
Sorry to have to tell you but it’s not just the BIOS. The chipset controlling the hard drive will not recognize the newer hard drives because of the number of heads and cylinders. It is a physical limit and the older computers will not give you the full capacity. It should work fine as is but the rest of the space is wasted. I wish I could give a fix but I have never been aware of one. Good Luck
Posted on Jul 21, 2009
    Sergeant:
  • 199 Answers
Is it formatted as NTFS FAT32 file system can only reconize 127 you must enable largr drive in the setup. but if you are using a image it wont give you that choice you will need to get a windows xp disk and use the driver / program disk to install you original software. you can also partition the drive into two particians to separate and it will then reconize the drives then you can mount the othe drive to a folder and then reclain all the drive space.
How can i upgrade from windows XP professional to windows vista for free?
you can't the system resources on the xp pc required to run xp are a lot less than what is needed to run windows vista.
how much ram and how much disk space !
it says 512 Mb ram but it will run like a snail
15 Gig of free hard disk space and a 20 Gig hard drive
https://support.microsoft.com/en-au/kb/919183
DO you have an upgrade copy of Vista ?
Nov 14, 2015 | Microsoft Windows Vista Ultimate Edition
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Which western digital hard drive is compatible with a hitachi travelstart 4200 rpm ata/ide? Currently running WinXP on Compaq V2000. Would like a hard drive that's a little faster and more than 60 gig.
Maybe you should be looken for a terabyte to upgrade it with though 4200 rpms isnt much and i dont know if western digital makes a terabye but you need to know the power demande for the replacement
drive and match them through demintion and power demand
Oct 18, 2009 | Computers & Internet
WD 250 gig ext hard drive
Hello there:
you may want to unplug the device for 3 min and hold in the power button or the reset button for 30 seconds and than power the device back up and see if this helps If not go to control panel and click on system and look for the device manager and see if it is listed there if it is click on the device and where it says remove say yes than click yes again than shut down and restart the computer and the found new hardware will start up and reinstall the device again for you. ok? please keep me informed how this is going,
best regards mike
Aug 03, 2009 | Western Digital My Book Essential Edition...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hardrive upgrade on IBM i 1400 Laptop ?
Hi! It's correct that your Thinkpad will only accept up to 512 mb of memory, and only certain chips will work with your unit. Here is a link that shows the memory that will work.
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=-1192&pid=399
Below is a link for recommendations for a hard drive upgrade. It looks like you can go up to a 250 gig drive using Western Digital. Hope this helps! Hal
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch3&model_id=-1192
Jun 05, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Problem After Upgrading Ram
clean your ram and motherboard dust it properly
with a clean cloth
if you satisfy with this solution rate it
Mar 31, 2009 | Computers & Internet
I have a Emachines T5026. I replaced the DVD drive because it went out. So I decided to upgrade other things. I upgraded my RAM from 512 to 1.5 gig RAM. Now I think I need to replace the fan because it is...
If you start noticing problems with random shutdowns or anything like that I would suspect your power supply, the new parts might overload the power supply, but unless you're adding new parts that weren't there before in addition to the old parts you should be fine. Computers can last as long as you are willing to keep replacing parts.
Mar 11, 2009 | E-Machines eMachines Desktop PC
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Toshiba Satellite 1905-S277 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
