Question about Cell Phones
How do I get to the part where I can enter my password and pin number
How to find Bluetooth pin number
The person you are pairing with, his phone will aso show "enter pin: " along with you, then both of you enter a same password. Say for example you entered "1" tell your friend to enter "1" Its simpleThe person you are pairing with, his phone will aso show "enter pin: " along with you, then both of you enter a same password. Say for example you entered "1" tell your friend to enter "1" Its simple
Oct 13, 2015 | Nokia Classic 2700 Cell Phone
I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can enter the bypass password: 5 6 7 8 and this will then allow you to go into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN? For the Original Firefly Phone:
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
Jan 05, 2011 | FireFly Cellular Phone
I am forgot my zen m26 mobile restore setting and privacy lock password..plz help me
i am forgot my zen m26 mobile restore setting and privacy lock password..plz help me
Jan 03, 2011 | Cell Phones
I HAVE NOKIA 3230.ITS MEMORY CARD IS LOCKED N I DONT HAVE PASSWORD. WHT WILL BE THE SOLUTION FOR THIS ISSUE
Tounlock cell phone Passwords:Instructions
Enter the last four digits of your phone number on yourcell phone PIN screen. Enter 9999, and if that doesn't work try 1111, and ifthat doesn't work try other 4 digit numbers you may have entered. Shut off your cell phone, take off the back of your phoneand pull out the battery. Record the IMEI number which is under the battery.Re-insert the battery and power on the phone. Enter the last 4 digits of theIMEI number on the PIN entry screen. Callyour service provider and request the unlock PIN. You will have to prove youare a customer by stating your cell phone number, addressand social security number. Turn off your phone. Hold thekeys "3," "*" and "Call" and switch the phone on.Hold the three buttons down until the word "Formatting..." appears onthe screen. This should reset the phone lock code. Read more: How to Unlock a Cell Phone Password ' eHow.comhttp://www.ehow.com/how_4810931_unlock-cell-phone-password.html#ixzz19YU6TIa2
Jan 03, 2011 | Nokia 3230 Cellular Phone
I forget my password i enter 10 times will it shut down will my phone still work all info remove
Tounlock cell phone Password:Instructions
Dec 31, 2010 | RIM BlackBerry Bold 9000 Smartphone
Unable to retrieve voicemail does not accept new password
Reset voicemail password from AT&T's automated system
Call 611 or 800-331-0500.
Enter the wireless number starting with area code.
Press 3 to "get help with voicemail."
Press 3 to reset your VM password.
Enter the Billing Zip code for the account.
After a few seconds, iPhone will display "Password Incorrect - Enter Voicemail Password."
Enter the last seven digits of the wireless phone number and tap OK.
Reset voicemail password from AT&T's website
NOTE: You must be registered and logged into myWireless Account to view this information.
From the myWireless Account home page, select Phone/Device then choose the Reset Voice Mail PIN link from the left column.
IMPORTANT: If there is more than one line on the account, make sure the correct wireless number is displayed in the Wireless Number list before selecting Reset Voice Mail PIN.
To reset the password for any of the lines on the account, choose a wireless number from the dropdown menu
Click Submit.
Dec 17, 2010 | Apple iPhone 3G
Suddenly getting "password incorrect" message for
Enter the wireless number starting with area code .
Click Submit.
Nov 01, 2010 | Apple iPhone 3G
It does not seem that my voicemail is working and i cannot remember my password for voicemail on iphone
Click Submit.
Aug 08, 2010 | Vtech 9009111 Cordless Phone
Why won't my voicemail password does not work
Click Submit.
Jun 24, 2010 | Lands Phones
Keeps saying phone freezed then enter password \
password is usually the same as your PIN number, if you haven't changed your PIN number the factory set one is either 0000 or 1111
Mar 06, 2009 | Samsung SGH-E370 Cellular Phone
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
