Question about GPS
When I plug my XL into my laptop, the light comes on but not the screen. The device has been out of use for some time. Can you help?
Download map update
the tom tom comes with a usb cable that plugs it to the usb port on the computer. When pluged in to the usb port it should automaticly take you to the tomtom web sight where you can download maps
Jun 12, 2010 | Tomtom ONE XL GPS
BLANK SCREEN BUT GREEN LIGHT ON SAT NAV STOPPED WORKING - GREEN LIGHT IS ON BUT NO DISPLAY ON THE SCREEN? HAVE PRESED THE RESET BUTTON BUT NOTHNG IS HAPPENING? CAN SOMEONE PLEASE HELP.
My guess is the wires that come from the screen and plug in the circut board have been jarred loose they my be all the way unplugged and just cocked to the side. if you r brrave enough to open it up its a easy fix. or you could send it to garmin and pay a couple ben franklins to have them fix it. either way good luck
Mar 29, 2010 | Tomtom ONE XL GPS
English
Sorry if this does not work but try preferences and then click the arrow about seven times until you come too the icon with three flags, click this and then you should be able to read it after
Feb 06, 2010 | Tomtom ONE XL GPS
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Nov 09, 2009 | Tomtom One XL GPS Receiver
Tomtom One XL Not recognized by pc
I've fixed quite a few of these units with this problem. I can diagnose for free (just return postage) and fix for a nominal fee (if fixable)
paul@cosmicstudios.co.uk
Sep 23, 2009 | Tomtom One XL GPS Receiver
Where is This product code on tomtom XL
I assume you mean the device ID code. Start your tt and go to the map screen, if it isn't already displayed. Tap the bottom right hand corner where the GPS signal meter is. On the next screen tap the version number. The next screen that comes up will have your device ID code, among other things.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Password issues with tom tom one xl
I got this similar password problem with Tomtom One XL. I just solve this problem step by step under the following ways.
1. Connect One XL to TomTom Home in your computer using USB cable and switch on ONE XL. (Click YES to connect each other)
2a. Click "Manage my ONE XL"
2b. Click "Items on device" tag.
3. Now you can see all of the data in your device and click "Applications".
4. Click inside the check box and click "Copy items to computer".
(This step is back up for just incase)
5. After Backing up your applications, then Click "Applications" check box and click "Remove from device".
6. After removing applications, unplug from computer and switch off ONE XL.
7. Connect ONE XL and computer again and switch on your ONE XL.
8. TOMTOM Home will search your applications in your device. Finally it will automatically download and installed the new applications. (There will be 4 times installation and the device will restart itself. At this step, you need to touch "Yes" on your device to connect the device and computer.)
9. After installation completed, your device looks like newly come out from the factory.
10. Set up Language, Time, and so on and ready to use.
Enjoy it
Austin Tan
Feb 10, 2009 | Tomtom One XL GPS Receiver
TomTom ONE XL will not power up or charge in my vehicle.
your fuse is burnt up to your cigarette lighter power supply try it in another car
Jul 12, 2008 | Tomtom One XL GPS Receiver
My screen shuts down
try to remove the hard drive, dvd and power on again.
some devices could cause that problem.
Dec 13, 2007 | Computers & Internet
No power-up
See if this helps-
Unplug the power adapter. Remove the battery. Plug in the power adapter. Attempt to power up.
If that doesn't work-
Power down. Remove the hard drive and CD drive, also floppy drive if you have one. Disconnect the cables to any external devices that you might have attached. Remove all of the memory cards. Replace 1 memory card in the main slot,only. This will reseat the memory card. Power back up and see if the system comes up to a BIOS screen. If not, and you have more than 1 memory card, try swapping to the other memory card. If BIOS comes up, start reinstalling each item (Hard drive first) one at a time, attempting to bring the system up after each item is installed. If the BIOS screen doesn't come up with everything disconnected, you'll need to disconnect the LCD screen (internally) and hook up an external screen. If BIOS shows up on the external monitor at this time, you have a bad LCD screen.
If nothing in this process seems to work, you probably have a bad mother board.
If you have any questions, please ask.
Thanks!
Ron-
Nov 09, 2007 | Toshiba Satellite M105-S3004 Notebook
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
