Xeroxworkcentre 7345 error 007-276 Tray 3 Paper Size Sensor Broken what can I do
flopez
  • 161 Answers
SOURCE: no paper error
Your unit has a bad paper sensor. It can give you one of two incorrect messages: (1) no paper when it actually has or (2) no paper on the unit but no error message. Genuine Service Centers can show you actual schematics and Samsung's Service Page on the Internet. Or better yet, visit www.samsung.com and find an authorized center through the SUPPORT link.
Posted on Sep 21, 2007
  • 58 Answers
SOURCE: paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
jqsababa967
  • 145 Answers
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Posted on Apr 26, 2009
SOURCE: Paper Size Error: The specified custom paper size is not supporte
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Posted on Oct 20, 2009
n25an
  • 622 Answers
SOURCE: wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Posted on Dec 20, 2009
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Cp305d paper size error
It may be a sensor problem When you reseat the tray it may not be actuating the paper size switches correctly. Check the paper tray and make sure that there aren't any missing or broken/bent tabs on it.
Mar 17, 2014 | Office Equipment & Supplies
Error 007-276 xerox
  • Check that the paper size setting is correct
  • Check the switch actuators on Tray 3, for wear or damage. Repair or replace as required
  • Check the Tray 3 Paper Size Sensor for damage or incorrect mounting
Dec 28, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Error code 008-900
This error does not indicate a specific sensor. Need to check all the paper path sensors (TRAY 1,3,4, registration sensor, the sensor duplex sensor transfer roller 2, the sensor fusing)
HOpe this helps.
Oct 16, 2012 | Xerox WorkCentre 7328 7335 7345 7346...
What does error 60.03 mean?
This has to do with the paper lifter for tray three. There could be any number of problems with the lifter or tray;
1. incorrect paper size - i.e. someone loaded letter in the tray that is mannually set to legal and didn't change the manual paper slider to letter or papers stuck in the tray,
2. manual paper lifter isn't working properly, motor spring could be broken or out of place,
3. the paper tray could be broken and you will need to replace the tray.
First check that the correct size paper is loaded properly in the tray and that there is no paper detritis stuck anywhere. If the tray has the correct paper and there is not paper detritis then swap tray 2 and 3, reboot the printer and see if the problem moves with the tray - it should become a 60.02 error. If this happens then it is a tray issue. If you still get a 60.03 error then it is a tray 3 lifter motor issue, here is a link that explains what needs to be done.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1297720042315+28353475&threadId=1389969
A lot of the time there is a loud pronounced clicking or banging also associated with the problem. The noise happens during the paper pathway test shortly after you turn the printer on and will display the 60.xx error code instead of the ready status.
-Connie
Jan 11, 2011 | HP LaserJet 4700 Printer
Xerox phaser 7760 sends fault error code 007-274. Won't go further. -john
This error means there is an open circuit in the Paper size sensor, in Tray 1/MPT.
It could be a broken wire in the tray assembly, or a fault on the Engine control interface board.
The voltage at the sensor should be about 3 VDC. (Pin 1 of Plug J610)
Dec 22, 2009 | Office Equipment & Supplies
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Xerox Phaser 7700 displays error 7-276
Here is the documentation on that error
07-276 TRAY 3 PAPER SIZE SENSOR BROKEN (TTM)
EXPLANATION
An abnormal AD value was detected from the Tray 3 Paper Size Sensor.
Refer to BSD: CH7.4 CH7.13A
Procedure
Set Tray 3 in the machine.
Between Tray Module PWB J548-11 (3T: J548-11 , TT: J548-11) (+) GND (-)
Is the voltage the same as that in the Tray 3 Paper Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) (+) GND (-)
Is the voltage the same as that in the Tray 3 Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-1 (3T: J820-1 TT: J820-1 ) (+)J820-3 (3T: J820-3 TT: J820-3) (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits to Tray 3 Paper Size Sensor J820-1
(3T: J820-1 TT: J820-1 ).
(WN 7.3.6 +5VDC-2)
Check for malfunctioning paper guide, poor contact caused by bending in the projection that pushes the switch, and
if there is no problem, change the Tray 3 Paper Size Sensor. (PL16.1)
Check for cut wires, poor connections between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) and Tray Module
PWB J548-11 (3T: J548-11, TT: J548-11)
Change the following parts successively:
TRAY MODULE PWB (PL16.9)
MCU PWB (PL13.1)
ESS PWB (PL13.1 ).
Apr 26, 2008 | Office Equipment & Supplies
154 people viewed this question
k24674
jasbo
jasbo
