Question about Cooktops
One hob burner not staying lit - Cooktops
SOURCE: burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Posted on Nov 18, 2007
  • 150 Answers
SOURCE: Sparking ignition
switch Is stuck in on position
Posted on Apr 23, 2008
SOURCE: SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Posted on Aug 10, 2008
  • 2976 Answers
SOURCE: four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Posted on Jan 04, 2009
bobhifi
  • 635 Answers
SOURCE: We have a problem with two of the burners on our
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Posted on Mar 07, 2011
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Four burner gas hob
Jan 04, 2009 | Cooktops
Sparking ignition
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
SPV577x Hob
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Burner ignites but doesn't stay lit
The Thermocoupler is faulty or has a bad connection - once the burner is lit, it heats the thermocoupler which then send a small signal to the valve to stay on - at that time you release the knob and the valve stays on ( supplies gas). If you give me a model number, i can get you a part number and price.
Jan 23, 2008 | Miele 23 in. KM360G Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
Cooktops Logo
76 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
