How do I reverse the primary leads on a furnace
  • deton8 von Splosion Dec 20, 2016
    What kind of heater... make & model... ??
    Why would you want to?
    Having trouble even forming a picture of your HEATER... let alone your TROUBLE... and... there's absolutely no EXTRA CHARGE for a reasonably detailed question (which would OBVIOUSLY help get you a decent answer. Soooo
    HOW about you give us a decent shot at being able to help??
    Either REPOST a less cryptic question or EDIT this on into a better one ...
    Happy Holidaze
Furnace wont always turn on
make sure u have a new fiering nozzel it need to be changed every year, if good check and clean you cad cell, if still problems replace oil primary
Dec 23, 2015 | Heating & Cooling
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
How to replace voltage regulater
Disconnect the battery.
Unplug the alternator lead going into the upper front of the primary cover.
Disconnect the reguator wire from the main circuit breaker.
Unbolt and remove regulator.
Reverse for installation.
Jul 03, 2014 | Harley Davidson Motorcycles
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
Blower comes on ,no flame most of the time,but when flame comes on it only lasts for a few minutes then stops. light flashes 4 times,i have replaced primary limeter to no avail.?
Your sensor is dirty. The sensor is the little rod that sticks in to the flame. It is just a little bigger around than a pencil lead and has one wire connected to it. It will be mounted just a few inches from the ignitor glow coil.
Turn power off to furnace
Take the sensor off
DO NOT wash it.
Take emory cloth or very light sand paper and lightly brush the steel rod of the sensor
You can also use a fine wire brush.
Put it back together and fire the furnace up again, chances are you've fixed your problem
May 28, 2011 | Goodman Heating & Cooling
Hi, I have a Janitrol GMPN060 natural
HI Check you air filter in clean , jump out the pressure switch see if it starts are the fan motors clean also check out the fan control hope this helps
Feb 12, 2010 | Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
A carrier furnace
check the relay
the primary should have a low resistance
there should be a distinct click when 24 volts is applied to the primary
the secondary should be conductive when the primary is energized (contactors can corrode)
not a solution something to check
Oct 02, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
