Question about Sharp Office Equipment & Supplies
Good morning to you, please my sharp copier MX-M160 suddenly started showing error on the screen, This the error(DOWNLOAD MODE). Please I need your assistance, thanks
Bubbabear64
  • 2794 Answers
SOURCE: Copier Driver for Sharp
Click here to get the file downloaded
Posted on Jul 31, 2008
  • 32 Answers
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Posted on Mar 25, 2009
  • 9 Answers
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
Posted on Oct 30, 2009
hamzaskilltd
  • 316 Answers
SOURCE: I use Sharp AR-M150 3-in-1 Copier. I was scaning a...
heat roller low temperature detection
Posted on Jun 12, 2010
  • 11 Answers
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
Posted on Jul 13, 2010
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
I cant clear H2 problem on sharp AR-M160 copier machine
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
The thermistor is open. The fusing unit is not installed.
Mar 29, 2012 | Sharp AR-M160 Black and White Copier
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
Sharp ar-m160
enter the simulation mode:
"#" key Interrupt key "C" key Interrupt key
press 14 and START key
the copier should restart in most cases.
if not:
There is a problem in the fusing area, bad Thermistor, defective ThermalFuse, defective heating lamp.
Jan 26, 2010 | Sharp AR-M160 Laser Printer
Sharp ARM-160 I have an error code L4-11.....any ideas?? Thanks
Please verify the continuty of the LAZER UNITSand the POLLYGON MOTER is.The problem in pollygon moter
Nov 02, 2009 | Sharp AR-M160 Laser Printer
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Ch error
Some of the covers of the machine might be open.
Regards,
Cäppärs
Jul 17, 2008 | Sharp AR-M160 Laser Printer
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
